First post, by silikone
- Member
I'm inexperienced in the field of retro computers, so I am hoping that you guys can help with a good start.
To start out with, I would like something with a Voodoo 5 video card in it. If I can, I will also get a sound card capable of A3D.
I'll probably get some kind of Pentium 3 processor, but I can't decide what chipset/motherboard I should get. According to Wikipedia, the 440BX chipset only supports AGP x2. I believe that Voodoo 5 cards are AGP x4. If this is the case, then is the 820E chipset a good choice? Unlike the 440BX, it uses neither SDRAM nor the slot 1 socket. Does this have any drawbacks in terms of compatibility?
Also, I have the original Windows 98 on a disc. Does W98SE add anything worth upgrading for?
Do not refrain from refusing to stop hindering yourself from the opposite of watching nothing other than that which is by no means porn.
