First post, by elianda
Hello,
I saved yesterday a Imagraph IPX card out of a quad 486 system from the trash.
Here is an image of it: http://mail.lipsia.de/~enigma/forum/imagraph_ipx.jpg
It seems to be similar to the imagraph portrait plus thats listed at Total Hardware 99.
http://artofhacking.com/th99/v/I-L/52072.htm
Still, does anyone has a source of the manual or jumper description or any software that supports this card that could give some video output to check if the card works?
It seems that originally there was a development kit for this card, but I couldn't find that anywhere.
Youtube Channel
Reply 1 of 3, by iulianv
Quad 486? I would have saved the whole system from the trash, not only the Imagraph 😀...
Reply 2 of 3, by elianda
Well the situation was a bit hectic, since I got aware of the electronics trash when the trash truck was already 2h overdue. There were slots for two CPU boards (2 CPUs each) in the system and one of it had a plugged board where just one socket was soldered. So in the end only one 486DX2-66SL was equipped and no real upgrade option. (not even for two 486)
Youtube Channel
Reply 3 of 3, by shspvr
Look like the same card with the same jump setup with 128k memory
I like see a screenshot of that Quad 486
