First post, by kataniel
Hello folks,
I installed a SPEA V7 Mirage P64 2MB VLB in my Dell Optiplex 486 DX4 machine. The onboard graphics (CL542x) is now disabled.
DOS boots fine, no errors.
But every time, I try to run a game (DOS, Privateer, etc.) the refresh rate goes up to 78Hz, which is too much for my 19" TFT.
Can anybody tell what is the cause (and perhaps a solution) for this high refresh rate?
Because of this, I also cannot run 3dbench2 and vidspeed40. The same issue there: 78Hz.
Thanks in advance for your help
kataniel
Reply 1 of 5, by swaaye
Try out this S3 DOS refresh rate utility. It should work for 864.
Reply 2 of 5, by kataniel
Thank you, I'll try it tomorrow and let you know again
Reply 3 of 5, by LowSpec486
Thanks, that utility has allowed me to use my 486 with my 19" TFT monitor at 1024x768 resolution in Windows 95, using its original VGA card which is a VESA "S3 Trio32" with chipset 86C732-P.
Without that utility, when setting the display in Windows 95 to 1024x768 it would go to a refresh rate uncompatable with my TFT monitor, and it wouldn't work.
Reply 4 of 5, by FGB
A program called "S3VBE" helps. It does help for VGA-mode, too. I tested it with my Mirage V7 VLB.
www.AmoRetro.de Visit my huge hardware gallery with many historic items from 16MHz 286 to 1000MHz Slot A. Includes more than 80 soundcards and a growing Wavetable Recording section with more than 300 recordings.
Reply 5 of 5, by dirkmirk
Another option is to use a DVI interface but of course it does'nt exist on a VLB video card, I found this problem with Commander keen with ISA CL5434 & VGA pci Voodoo3, radeon 9800se with dvi displayed the picture fine.
