First post, by SGIsoverMarcel
Hi everyone,
For my job, I intend to replace a 20 years pentium by a brand new PC to run a dos app.
The pentium is used to control a production line (automatism) and because of a lack of credits, the IT team has kept this system alive.
But now, there is no more spare part for the old computer and so, before its death, I have to find a way to replace it with a brand new one.
I use Dosbox at home, I see its performances on old games and I also like the way it's easy to configure, but I'm blocked with the serial port configuration:
- I've declared serial 1 to 4 as directserial realport:COM1 to 4
- I launch the emulation and start my program
* the program is launched (no error message)
* I physically plug the serial port 1, and then I've got an error message in the dosbox console:
Serial1: Errors:Framing 97, parity 0, overnum RX:0 <IF0:0>, TX=0, Break 67
The figures after framing and break are different at each line.
These lines are written repeatdly (1/second)
What can I do?
Thank you
Marcel
Marcel
Reply 1 of 11, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Don't use Dosbox for mission critical stuff. Seriously, it is not meant for that, only for games. You better build a dedicated dos machine for that.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 11, by Jorpho
What Dominus said.
Also, be careful if you're using a USB-to-serial adapter; in my experience they may not work as well as a real serial port, like the kind you can get on a PCI I/O card.
Reply 3 of 11, by SGIsoverMarcel
In fact, we're already working in a critical mode.
Dosbox is just a mean to give some month to replace all the supervision.
The new PC is equiped with pci serial cards and I just want to understand the message:
in order to fix it.
I really thank you for your advice, and I'm working on several fronts (virtual box is another one for example)
Thank you
Marcel
Marcel
Reply 4 of 11, by Dominus
DOSBox Moderator
What I meant is that Dosbox might not work precise enough to be trustworthy. The question is not whether it will break something in your production but when. Just build another dos machine and have that ready when the old one dies.
Reply 5 of 11, by SGIsoverMarcel
I know that it is not recommended but the IT maintenance team have already perform test on newer PC and it doesn't work ==> too fast for the hardware (not the pc but the other devices)
If I buy an old pc to a broker, it's also risky ==> an old PC risks to die like mine
So I really ensure you that Dosbox is one of my low risk exploration.
Do you have any idea about the error message:Serial1: Errors:Framing 97, parity 0, overnum RX:0 <IF0:0>, TX=0, Break 67
Thank you
Marcel
Reply 6 of 11, by Dominus
DOSBox Moderator
so it already died? But yes I didn't mean to suggest you use a new PC but that you keep another old Dos machine as backup in case the main machine dies or, better, build a third one as well. If all you need is DOS this can be done without too much of hassle. I honestly can't believe you are eager to trust your production to an emulator instead of the real thing...
The error message doesn't tell me much but perhaps the machine you are testing on is also too fast or you need to test out the various speed settings for the com ports in the device manager.
Reply 7 of 11, by SGIsoverMarcel
so it already died?
No, the former one died last summer, and its substitute is running 24h a days, 7 days a week since july 2011.
If it crashes, we have no more spare parts...
OK, I'll try, thank you
Marcel
Reply 8 of 11, by Dominus
DOSBox Moderator
Really for this kind of work... *sounding like a broken record* ... use a real PC and not Dosbox...
Good luck
Reply 9 of 11, by SGIsoverMarcel
I'm glad to tell the forum that the new PC is plugged and works with the 0.74 version of DOSBox.
In fact the error message is nothing
Marcel
Reply 10 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
Let's see how it works after 21 days of continuous usage.
Some important variable(s) signflip then if I recall correctly.
Water flows down the stream
Reply 11 of 11, by SGIsoverMarcel
A vaincre sans péril, on triomphe sans gloire (le Cid, Corneille, 1637)
to win without risk is to triumph without glory
The risk my old computer crashes is a million times worse than restarting a software in less than 2 minutes.
So let see.
Thank you for your help and your advice.
Marcel
