First post, by daibido1123
Hi guys, I'm trying to get my copy of Slave Zero installed on my laptop so I can play when on the go, problem is it won't work with me. I've tried everything, and am looking at DOSbox, but even then with it, the game will not even launch the installation wizard, any advice?
Thanks!
Learning without thought is labor lost; thought without learning is perilous
Confucius
Reply 1 of 7, by bloodbat
Don't run a Windows game under DOS?
Reply 2 of 7, by Glitchologteam
Ive checked basic information about the game and It seem that the game was designed to only work on Windows ME and 95/98. There is also apparently a fan made patch that allow you to play it on newer operating system (but it require the original CD to run it). I can't seem to find it by googling, however. I don't know if semeone has that patch
One thing for sure, you can run it on DOSBOX by installing a operating system inside but it will be waaay more easier on a virtual machine like VmWARE or if you find the patch
Reply 3 of 7, by leileilol
NO YOU CAN'T RUN SLAVE ZERO IN DOSBOX
There's not even any accelleration for Direct3D which Slave Zero absolutely requires
also no cdrom drive in 9x hampers things
Stop wasting your time
Reply 4 of 7, by Glitchologteam
oh well, I thought it was possible to run Win 9x game on dosbox like starcraft, diablo or crocs, but those game probaly do not require accelerated direct x.
Reply 5 of 7, by bloodbat
At least Starcraft runs well by itself under Win 7 x64.
There's a patch somewhere here to fix the messed up colours, you can patch the registry by hand or you can suspend explorer with Sysinternal's PsSuspend; Diablo would probably work that way too.
Reply 6 of 7, by Glitchologteam
you dont need any patch to run those game. You only need to change the background to high contrast and let the screen resolution windows open. Alot of game need that setup to run without any glitches.
Sometime setting the compatibillity to Windows 95 or 98 fix game that run only on specific system (but this do not work for installation, you really need a virtual machine for that). I don't know if this apply for slave zero, the thread author could try that
Reply 7 of 7, by bloodbat
Useless open windows annoy me, hence, I preffer editing the registry.
