Descent II installation error
Reply 20 of 27, by mspc
the names are descent2.iso and descent2.bin, minding case.
and there are a few versions of the instructions, some say -t iso and others say -t cdrom, and some say to include -fs iso and some don't. But as you can see, I tried all possible combinations.
edit: is there a way I can check if the cue file is referencing the correct bin file?
Reply 21 of 27, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
please post the contents of the cue file. You are confusing me with the descent2.iso - where does that come from? If the bin file referenced in the cue is written the same way and case as written in the cue, no path in the cue and cue and bin files in the same folder it should work.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 22 of 27, by mspc
i meant descent2.cue, not /.iso. sry
I'll post the contents of the cue in a moment.
Reply 23 of 27, by mspc
descent2.cue:
CD_ROM
// Track 1
TRACK MODE1_RAW
NO COPY
DATAFILE "descent2.bin" 38:15:22 // length in bytes: 404889744
// Track 2
TRACK AUDIO
NO COPY
PRE_EMPHASIS
TWO_CHANNEL_AUDIO
SILENCE 00:02:00
FILE "descent2.bin" #404889744 0 00:40:24
START 00:02:00
// Track 3
TRACK AUDIO
NO COPY
PRE_EMPHASIS
TWO_CHANNEL_AUDIO
FILE "descent2.bin" #404889744 00:40:24 02:36:45
START 00:00:27
// Track 4
TRACK AUDIO
NO COPY
PRE_EMPHASIS
TWO_CHANNEL_AUDIO
FILE "descent2.bin" #404889744 03:16:69 01:55:39
START 00:00:26
// Track 5
TRACK AUDIO
NO COPY
PRE_EMPHASIS
TWO_CHANNEL_AUDIO
FILE "descent2.bin" #404889744 05:12:33 02:29:33
START 00:00:05
// Track 6
TRACK AUDIO
NO COPY
PRE_EMPHASIS
TWO_CHANNEL_AUDIO
FILE "descent2.bin" #404889744 07:41:66 03:02:44
START 00:00:14
// Track 7
TRACK AUDIO
NO COPY
PRE_EMPHASIS
TWO_CHANNEL_AUDIO
Show last 56 lines
FILE "descent2.bin" #404889744 10:44:35 02:28:35
START 00:00:23
// Track 8
TRACK AUDIO
NO COPY
PRE_EMPHASIS
TWO_CHANNEL_AUDIO
FILE "descent2.bin" #404889744 13:12:70 03:23:36
START 00:00:21
// Track 9
TRACK AUDIO
NO COPY
PRE_EMPHASIS
TWO_CHANNEL_AUDIO
FILE "descent2.bin" #404889744 16:36:31 02:50:18
START 00:00:13
// Track 10
TRACK AUDIO
NO COPY
PRE_EMPHASIS
TWO_CHANNEL_AUDIO
FILE "descent2.bin" #404889744 19:26:49 02:45:39
START 00:00:09
// Track 11
TRACK AUDIO
NO COPY
PRE_EMPHASIS
TWO_CHANNEL_AUDIO
FILE "descent2.bin" #404889744 22:12:13 02:42:43
START 00:00:06
// Track 12
TRACK AUDIO
NO COPY
PRE_EMPHASIS
TWO_CHANNEL_AUDIO
FILE "descent2.bin" #404889744 24:54:56 02:18:05
START 00:00:07
// Track 13
TRACK AUDIO
NO COPY
PRE_EMPHASIS
TWO_CHANNEL_AUDIO
FILE "descent2.bin" #404889744 27:12:61 02:53:51
START 00:00:04
...all looks well to me.
Reply 25 of 27, by mspc
Okay, I got it to work. I was using cdrdao which was making a .toc file instead of a .cue file. I used toc2cue to convert it, and mounting worked. I've installed Descent II, but there's one problem: the redbook audio is white noise. This has something to do with cdrdao I think. As far as this thread is concerned, problem solved.
Reply 26 of 27, by Dominus
DOSBox Moderator
glad you got it to work. Unfortunately it seems like the *nix tools aren't that good at creating bin/cue images. So far I've had to resolve running Alcohol 120% in a Windows VM to get proper images 🙁
Reply 27 of 27, by NY00123
The noise thing might be a byte-order related issue. See the following page for solving that, if you agree to re-rip the contents from the original CD:
http://www.dosbox.com/wiki/Cuesheet
As an alternative, if you don't wish to touch the CD again, you *might* be able to externally mount the bin+cue (or bin+toc) as a virtual drive with cdemu, and then re-rip with cdrdao to swap the byte order (from the drive mounted by cdemu). I'm unsure it's better than re-ripping from the CD itself, though.
