First post, by kool kitty89
How reliable is the VA-503+ or VA-503A? And, in the case of failure, what are the root causes?
I've seen a lot of mixed information about this: many stories of 503+ boards dying (not much specific on what goes bad), and others describing it as exceptional all-around in performance, compatibility, and reliability.
Red Hill's motherboard guide/museum, in particular, gives heavy praise to the 503+ as seen here: http://redhill.net.au/b/b-98.html
and here: http://redhill.net.au/b/b-00.html
What seems to be universally agreed upon with the 503+ is that the jumper layout is both complex and confusing, and that the board was also the benchmark standard for Super Socket 7 performance.
Again, I've seen very little info on what causes them to fail, but from the comments I have seen, dying BIOS chips are mentioned (especially problematic on some models with the BIOS soldered in). It also seems like some earlier revisions are particularly problematic. (which may explain the inconsistent reliability accounts -perhaps Red Hill mainly dealt with later model boards)
Also, all the bad/unreliable accounts seem to be from totally bricked boards, not quirky/flaky/unstable boards. (and also not AGP compatibility issues as seen on some other SS7 boards)
I've seen far fewer comments on the VA-503A, so I'm not sure how that compares (either in performance or reliability). I can comment on this one personally though, since the 503A system my dad and I build back at the end of 1999 is still working today. (the jumpers/switches also seem a fair bit easier to set up than the 503+ -and having a significant amount of that implemented as DIP switch blocks helps too)
Reply 1 of 3, by luckybob
I have several. All work. I also have the ali5's as well and there really isnt much of a noticeable difference. As for jumpers, that is more of a manufacturer thing than anything else. I had a TYAN board based off the 503 and it was so easy to jumper, a blind man with no fingers could do it. I also have a board that has lots of jumpers and none seem to be marked. Its a no-name Taiwan P.O.S. I think the real appeal of the MVP chipset was the 66mhz ram flexibility. Allowing people to use their old ram is a BIG selling point. You can save your old ram in a new board, wait 6 months and get new ram.
Now once you get into overclocking, in "MY" experience, the Asus P5A-B is KING. Easy jumpers, and memory over-voltage options! (Aladdin 5 chipset though)
My advice would be find a name brand board, with the features you want and you should be fine. If you want to experiment and/or overclock, i'd get an Asus P5A-B. If you want something that is known for no-frills stability and high performance, I'd look for a tyan S1590. There are also ATX versions but i assume you know how to google.
Reply 2 of 3, by noshutdown
man i believe ali5 boards performance are far superior over mvp3 ones, unfortunately they have HUGE agp issues in win2000(win98 seems ok anyways). i have tried gigabyte rev4.1 and rev5.2, both vulnerable to this, and i doubt asus ones would be much better because p5a rev1.05 and newer have bugs with k6-2+/k6-3+, while rev1.04 uses old version of ali5 chipset, which is supposed to have more compatibility issues.
so, maybe i got to give mvp3 boards a try, and my favorite name brand goes to dfi.
Reply 3 of 3, by kool kitty89
Hmm, different branded 503 boards? Or do you mean other, similar, MVP3 based board apart from FIC's VA-503+. (FIC should be the only manufacturer of that specific board, and that -along with the ATX PA-2013- are known for there difficult jumper layouts)
Heh, that sounds like the FIC board right there . . . FIC IS a Taiwan company, and the boards I've seen aren't very obviously marked either. (sometimes no FIC markings, just a part number and VA-503+ written -though my 503A had "FIC VA-503A" printed in big letters across the middle of the board)
If it has 4 SIMM and 2 DIMM slots, 3 PCI, 3 ISA, 1 AGP, it's almost definitely the FIC 503+. (I'm not sure if any other MVP3 boards supported 72-pin SIMMs, or at least not any common ones)
Edit: hmm, except the real FIC 503+ boards tend to at least have the jumpers marked (if in a confusing manner), so I'm not so sure here. (unless they also made cheap-o versions that skated on printed labeling -though that would be an odd area to save cost)
Not just the decoupled RAM/FSB speeds either, but also the support for both SIMMs and DIMMs in the case of the 503+. (albeit not in many other MVP3/MVP4 based boards, including the 503A -not that that's a problem for what I'd want anyway)
There's smaller steps in clock rate too (105, 110, 115, 120 -vs 112 and 124 on MVP boards).
Weren't there also some ALI chipset SS7 boards with 133 MHz options too? (and 1/4 PCI dividers -something that would also be useful for stability at 120 MHz . . . and would have been quite useful on MVP boards for 124 MHz -as it is, you run into the same overclocking issues as 83 MHz FSB)
I think I'm happy with that 503A I have for now, but I was curious about the 503+ (both from a historical perspective, and as a possible alternative/replacement option if the 503A ever dies or for other reasons -my 503A is only the 512k cache version, plus having more than 1 ISA slot could be useful). OTOH, the 503+ can't take 2 long PCI cards, but the 503A can. (though I only have 1 voodoo 2 currently)
The 503+ seems to be among the most common SS7 boards out there, and it's also the only type I've seen show up at WeirdStuff warehouse this year.
The MVP based boards tend to need a BIOS update to work with the K6+ models (some ALI boards too -the GA5 doesn't though).
As for performance, I'd really gotten the impression from old reviews/articles I've found online that the MVP3 was the benchmark leading standard of SS7 chipsets (and the VA-503+ was the top of those). Perhaps the comparison would be less favorable when comparing 512k cache MVP boards. (the standard configuration for the 503+ was 1 MB)
