First post, by metalfan
ive copied the cd to drive and run install.exe from dosbox, but the installer aborts with:
Can't open file: QICKSTRT.SAV (Free translation from the german error)
Jagged\ Alliance is the cdroot, so the file is there...but why does the installer abort?
Jagged\ Alliance/ROOT/QICKSTRT.SAV
greets
Reply 1 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
how did you mount everything ?
Water flows down the stream
Reply 2 of 8, by metalfan
i did a
cp -r /mnt/cd/* /hom/myuser/dos/Jagged\ Alliance
then i started dosbox
mount c /home/myuser/dos
c:
cd jagg..~1
install.exe
Reply 3 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
yeah that is probably not going to work
most installers want to be run from D and install on C (and D mounted as cdrom)
So try this
mount d "/home/myuser/dos/Jagged Alliance" -t cdrom
d:
install
Reply 4 of 8, by metalfan
thx, worked.
Reply 5 of 8, by manio
Hello,
i am experiencing the same problem and although your post helped me to get pass the "Can't open file QICKSTRT.SAV" error, now it stuck at a new one reading : "Can't open file DOS4GW.EXE for output!".
The file IS located at the /ROOT directory of the game files, and although i tried to mount it from the virtual CD-ROM and from hard drive (both with -t cdrom options) it couldn't find it.
im running WIN 7 64bit and trying to install to c:/program files (x86)
any help please ?
Reply 6 of 8, by leileilol
don't do that
nor
bumping up 2008 threads
Reply 8 of 8, by manio
Dominus wrote:
Use the 60 seconds guide from my signature. And don't bump four years old threads...
Holy cow, it worked! Thanks guys for the help and apologies for bumping an old thread but....well no "but" just thanks!
