PCI sound card in Futro s220
First post, by theelf
Hello to everyone, first sorry my english, im spanish
I bought a very nice Thin Client, Futro S220,
Crusoe TM5800 800 MHz
SIS 315E
1 PCI slot
Chipsets i see in motherboard
VIA VT1211
VT6103L (ethernet)
VT1612A (integrated audio?) (integrated audio work with VT8233 drivers)
My problems come with when i want to use a PCI sound card, I tried this sound cards, and same problem for all, the card is detected perfect, in DOS and Windows, but no SOUND
SB live!
SB PCI 128
CMI8738
For example, with the SBlive! the DOS drivers detect card, and assign IRQ for card, and SB emulation. Games detect sound card, but no sound output
If i use for example dos mp3 player, Mpxplay, detect perfect the SB live, start playing MP3, and all seems normal, but no sound
Same with CMI8738, and SB128
Of course, the sound cards work perfect in other computers
Same in Windows, card are detected perfect, the drivers work OK, winamp for example, play a mp3 like everything normal, but no sound
I dont know what to do, i tried all, but is the first time to me to have a working sound card, but the sound output not working
Thanks
Reply 1 of 8, by Davros
If integrated audio is working for you why do you need a pci card ?
ps: you dont have anything connected to the onboard audio ?
it has audio out and headphone out usually if you plaug anything into headphone out it cuts sound to the speakers (could be cutting sound to the pci card as well)
anything in the bios to disable onboard sound
Reply 2 of 8, by theelf
Thanks for reply
I need a PCI sound card, because the onboard have no DOS drivers
And in win98, the onboard, have no FM music
Nothing in bios to disable onboard sound, and i tried all experiments about plug-unplug stuff in the onboard sound.... 😅
I take some pictures to show my problem
The SB live is detected OK. Sorry i forget to take a picture of SB emulation, in 220 i5 d1
The sound card is detected OK in wolfenstein
... or in autodetection in Street Fighter 2 setup
Now... i unplug all PCI card, and run the CMI8738 PCI driver... normal, no PCI card
Now i plug the CMI8738 sound card in PCI slot, and run again. The card is detected in Wolfenstein, doom..etc all games, perfect
No sound output in the sound cards.
The sound card works OK in other machines, and yes, i have great speakers... 😀
Is a problem that i really dont have any idea how to solve.....
Reply 3 of 8, by Mau1wurf1977
Firstly this looks line a very interesting project. What performance do you get with such a CPU under DOS?
Other boards working isn't a good sign and it shows that you know how to set it up.
Does this board run Windows without any issues?
Usually speech is an issue with PCI cards, but FM not so much.
My YouTube channel
Reply 6 of 8, by theelf
Mau1wurf1977 wrote:
Firstly this looks line a very interesting project. What performance do you get with such a CPU under DOS? […]
Hi, in fact is a really nice PC
The performance is similar to a Pentium 3 400mhz, but.. better?
I have a real pentium 3 450 PC, and some games like Lotus 3, not work with a overflow error, but in the Crusoe works like a charm
For really old games, that works very fast, this thin client works very well for the Throttle software, because the VIA chipset
Games like Zaxxon CGA, works perfect in the Futro
The only problem is the PCI. I have two futro s220, and in both thin clients, all PCI sound card i test have no sound output
The internal sound card have no FM music in DOS box inside win98, and this kill last chance of a working DOS game machine... 🙁
About your question, I test in this thin client , win95, win98SE, Win2k, WinXP, linux, and OS/2 without problem. Is agreat thin client
I hope i can found a solution to the PCI sound problem, or the music inside Win98 DOS box using the internal sound card
Reply 7 of 8, by RichB93
Just in case others were wondering, the Crusoe TM5800 is a chip that emulates an x86 instruction set. It isn't 100% as far as I'm aware and eats around 12MB of RAM to store the emulation core. I have a thin client with one of these chips in and its amazingly slow. I'm guessing around P2-266 speeds. No MMX either I believe. Mine has a 16 or 32MB Radeon 7000/7500 however and it'll play UT99 quite nicely. 😳 😁 I'll try another PCI audio card in my thin client when I have time and get back to you with the results 😀
