First post, by Holloweye
Trying to play setters 2 with two players. First player need a USB mouse and second player need to be on the serial port with a mouse. My computer has no serial ports so I got HL-340 which is a serial -> usb converter. I got drivers for it and it seems to work.
Now when I start dosbox it get extremely slow (I can't even start settlers 2) when I have settings setup for my serial mouse.
serial2=directserial realport:com4
If I change it to
serial2=directserial realport:com3 < my mouse has com4 so just for testing without it and dosbox run at normal speed again.
I have tried change the bits per second and stuff for the mouse in the device managed without any result.
Anyone know how to fix this slow down? Thanks in advance..
