Reply 20 of 28, by sliderider
Malik wrote:
Why? Why did they release a GT 520 PCI card? Why? Why?.... Will it work with my 486 with PCI slots? If not, why? :lol: […]
Why? Why did they release a GT 520 PCI card? Why? Why?.... Will it work with my 486 with PCI slots? If not, why? 🤣
Now I've seen everything.
No, it won't because the PCI standard has evolved a lot since 486 days and it's not likely that it will be compatible on that basis AND it is not likely there will ever be drivers for any OS that still runs on a 486 motherboard unless someone decides that they are so determined to use one of these cards with an obsolete OS that they write their own driver and release it to the public.
Reply 21 of 28, by cdoublejj
like i said for phys-x when you have all PCIe occupied and or for older OEM PCI only mobos.
Reply 22 of 28, by ratfink
Good for messing about with cuda on a system with spare pci but not pci-e slots.
Reply 23 of 28, by RichB93
BigBodZod wrote:
F2bnp wrote:
Do these still exist? I mean seriously? No PCI-E or AGP at all? What kind of processor/RAM do these things have?
I can see many of the OEM's building micro-ATX boards with only PCI and/or PCIe x1 slots, this means no dedicated GPU support as you need a PCIe x16 slot for that 😉
It would still have current standard CPU's and DDR3 ram slots, most likley only 2 of these slots and a max ram support of 8GB.
While it isn't mechanically compatible, a PCI-E x16 card would work happily in an x1 slot. You can get mechanical adapters to do this.
Reply 24 of 28, by sliderider
Why would you want to? PCIe x1 isn't much better than PCI in terms of bandwith. You'd be choking an x16 card in that slot.
Reply 25 of 28, by shspvr
I belive that depend on how you look at it
PCIe
v1 offers per lane 250 MB/s in each bandwidth direction
v2 offers per lane 500 MB/s in each bandwidth direction
PCI is one way and a shared bandwidth
133 MB/s (32-bit at 33 MHz)
266 MB/s (32-bit at 66 MHz or 64-bit at 33 MHz)
533 MB/s (64-bit at 66 MHz)
Reply 27 of 28, by nforce4max
cdoublejj wrote:
http://www.newegg.com/Product/Product.aspx?It … N82E16814500221
they are good for phys-x when all other slots are occupied.
A cheap single slot 8800/9800GT owns any thing Fermi based that is below the GTS450 level performance and same for Kepler that is still less than the total performance of a gts450. Fermi cards however are so far better than Kepler and the older card for Folding.
Also got a Ageia for my one of my retro rigs to go along with a BFG 7800gs 😎
Typo >.<
Reply 28 of 28, by sliderider
nforce4max wrote:
A cheap single slot 8800/9800GT owns any thing Fermi based that is below the GTS450 level performance and same for Kepler that i […]
Typo >.<
There are no 8800GT or 9800GT that go in a PCI slot.
