Reply 20 of 43, by luckybob
I had a p3b-f back when it was new, and I remember something about the ps/2 mouse causing issues. Switch to a usb model and disable ps/2 and see what happens. I dont remember what the problem was exactly, just that there was one.
Reply 21 of 43, by PhaytalError
Ok so I elected to not use a wired NIC on that PC, I installed my Netgear Wireless card and the problem has stopped completely even with full internet access.
Also I cleared up the shared IRQ 9 with certain devices by disabling the onboard IDE channels [since I use an Ultra66 Promise PCI card], that cleared that up instantly.
@luckybob
Thanks for that hint, i'll give that a go as well to see if I can squeeze a bit more frames out. 😉
DOS Gaming System: MS-DOS, AMD K6-III+ 400/ATZ@600Mhz, ASUS P5A v1.04 Motherboard, 32 MB RAM, 17" CRT monitor, Diamond Stealth 64 3000 4mb PCI, SB16 [CT1770], Roland MT-32 & Roland SC-55, 40GB Hard Drive, 3.5" Floppy Drive.
Reply 23 of 43, by PhaytalError
Well I cleared up the sound skipping when the AGP card stutters by installing the Wifi card, however internet access [just simply dhcp connecting to it, or simply having internet access period] regardless if the game supports online or not is absolutely messing with the AGP throughput for some reason. I disable internet, BAM full speed AGP access in my games; no stuttering, no missed frames, none of that, but if I reenable internet access its stutter city for my games.
Online games such as Q3, etc are a total no go because of the stuttering; net access causing 1-3 second or longer pauses in the on screen action and I have no idea why.
This is bugging me to no end, and I am hoping to find a resolution for it soon, i've never had issues like this with an AGP card before, ever. Is it an issue with Windows 98SE or something that i've forgotten about, or is there just something weird going on with my system?
Reply 24 of 43, by Stull
Well, 12 years ago my "solution" was to use a 3Com 3c509 non-PnP ISA NIC and hard set the IRQ to clear up the conflict, but it sounds like you've eliminated that possibility.
What kind of encryption are you using on your wireless access point, if any?
Reply 25 of 43, by PhaytalError
AES encryption, btw i'd be using my 3Com 3c509 non-PnP ISA NIC if this motherboard had a free ISA slot, unfortunately it has only 1 ISA slot and that contains my SB16 card.
Reply 27 of 43, by PhaytalError
DosFreak wrote:
The sound is no longer stuttering because I added in a Wifi card, however the AGP throughput does still stutter anytime internet is "on"... i'm starting to think this is an issue with either Win98SE itself or perhaps 440BX chipsets?
Reply 29 of 43, by Mau1wurf1977
I had a ECS S754 board once and this PCI TV tuner would freeze the machine every now and then. I tried EVERYTHING and I got so fed up that I purchased a new Asrock board and that didn't have any issues...
But congrats for solving the problem.
My YouTube channel
Reply 30 of 43, by PhaytalError
Not quite resolved yet, but getting there...
im gonna take out my PSU out of my main PC and test it out on the Pentium III system and see if it's a PSU issue... I really doubt it, but then again the minimum WATT psu nvidia suggests is about a 300 watt for that FX 5500 and there is a 350 watt "generic" PSU in that PC, in this PC it's a 500watt Thermal take. 😜
Reply 31 of 43, by sebaz_ri
Maybe it's harddisk throughput stutter?
Try removing this card and using the integrated IDE ports
No way it could be that! But i'm almost out of ideas 🤣
Reply 32 of 43, by PhaytalError
The HDD led doesn't come on at times of stutter. That's how it acts though as if it's swap, but it's really not.
Tried that lastnight
🤣, I am too, I can remember back in the day when 440BX was still "the bomb" I was able to run Quake 3 online with my ASUS P3B-F v1.04 [same modle of motherboard I use now] overclocked Pentium III 450 @ 558Mhz, 256mb RAM, and Voodoo 3 3500TV and broadband on Windows 98 and never had this issue. That's why im confused as to what is going on, it didn't happen back then, so why is this happening now? 😵
Reply 33 of 43, by PhaytalError
I found the culprit! It's SOMETHING installed from the Unofficial Windows 98 SE SP3 by user PROBLEMCHYLD from the MSFN forums, that is causing the issue.
I re-re-re-REinstalled [yes, i've reinstalled multiple times trying to track down this but and now I finally have!], this time just plain jane vanilla Windows 98 SE, installed the latest Intel 440BX chipset drivers, the latest Nvidia drivers, and DirectX 9.0c... the issue was not occuring. I then installed the Service Pack and blamo, the issue resurrected itself! So it seems that I am gonna have to track down the "evil doer" package, and report the bug to PROBLEMCHYLD.
Reply 34 of 43, by luckybob
you sir have more patience with windows 98 than I do! I probably would have set the damn thing on fire by now!
Reply 35 of 43, by sebaz_ri
That's why i don't install some unofficial patchs, the only 'unofficial' thing in my W98 systems is the unofficial usb driver, nothing more
You don't need the latest intel drivers, and also the 61.76 driver have the best speed/compatibility ratio, instead of the latest 81.98 driver (i tested 61.76 with a Geforce4 MX4000 in my P3 1GHz 440bx system and this was the most stable,because 81.98 was even faster but it did have compatibility problems with GTA3 and Unreal Tournament)
Also in this thread
Hardware issue or just the games?
you mentioned that you have frameskipping with Voodoo 3 and Unreal,and that maybe was caused also by the unofficial SP3
EDIT:So basically now i know that installing SP3 is asking for trouble
Reply 36 of 43, by PhaytalError
Hi sebaz_ri,
Yeah i'm suspecting the stutter on the Voodoo 3 as also being related to the SP3 bug. I'll be reinstalling Win98 SE today [probably multiple times] because I need to see which patch in the SP3 is causing the issue, and then report it.
🤣, yeah years ago I wouldn't have had the patience at all, but now that im 31 i'm starting to get more patient about things in life. Although this issue has been nothing but a huge thorn in my side. 😜
Reply 37 of 43, by Mau1wurf1977
I know quite a bit about DOS but this thread really makes me want to do some W98SE projects. I have some experience as a kid just before I went overseas (I had a PII 300 with a Voodoo 2 and I left in 99/2000). The last games I seem to recall playing under W98SE was Wing Commander Prophecy, some Star Wars game, Blade Runner?, Tomb Raider 2 and a few other games.
And XP was just around the corner I believe. (1 or 2 years later).
I will have to do heaps of reading in order to get things right. Patches... Isn't W98SE not supported anymore?
My YouTube channel
Reply 38 of 43, by sliderider
Do you mean official support from MS? I'm not sure if you can even download the last patches from them anymore. You'd probably have to find a website of someone who has them archived.
Reply 39 of 43, by Mau1wurf1977
Yes that's basically what I mean. Like an offline Service Pack or something like that. Or did Windows 98SE update through the Internet just like XP?
I guess for playing games patches aren't that super serious right? As long as the main drivers are good (chipset, graphics, video card, directX and all of that).
I did find that third party USB driver so I could use USB Flash drives. Very handy 😀
