First post, by Bladeforce
Hi, can anyone confirm that The Web crashes Dosbox mac when entering fullscreen?
Thanks very much
Reply 1 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
Which mac os X version ? If it is a new one, try a build from the signature from dominus
Water flows down the stream
Reply 2 of 8, by Sune Salminen
Works fine here with the latest version of Boxer.
It's an issue between Lion and the SDL library.
You must use a later version of DOSBox that uses the 1.2.15 version of SDL where the full screen issue was fixed.
(just guessing, hope this helps).
Reply 3 of 8, by Bladeforce
i have version 0.74 and sdl 1.2.15 the game plays fine in a window selecting whatever options i want but as soon as i keypress to full screen dosbox quits to the desktop saying dosbox has unexpectedly quit
Reply 4 of 8, by Bladeforce
Sorry I meant to add that executing fullscreen from a window works fine in all my other games just not the web or timeshock
Reply 5 of 8, by eL_PuSHeR
[Thread moved to DOSBox Games/Apps. Section]
Reply 7 of 8, by Bladeforce
The SVN worked a treat thanks! May I ask what broke in the mac version and also does this SVN have glide support built in? What is different about it?
Reply 8 of 8, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
The official 0.74 version of Dosbox had SDL 1.2.14 compiled in, this SVN version has SDL 1.2.15 compiled in, that alone fixes tons of things broken by SDL.
SVN of Dosbox has all the changes to Dosbox sourcecode since the 0.74 version. No glide support though.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
