Sapiens - divide error
First post, by exofreeze
I am trying to get a game called Sapiens by loriciel (1987) running in dosbox 0.74.
When the game starts, a title screen pops up and seems to hold. After about 30 seconds it returns a divide error.
I have tried 0.74 with a standard conf as well as the SVN build. In the debug version I see this message at the divide error:
INT10:writechar used without attribute in non-textmode D 44
It seems this is a video mode error, however changing the video modes to other types gives me the same error. I have tried pcjr, cga, vgaonly, and svga_s3. Any ideas?
Reply 1 of 4, by peterferrie
your cycle count is too high. you need to run with a smaller value (50000 or whatever).
Reply 2 of 4, by exofreeze
um... it is running at 3,000 right now. well below 50,000.
Reply 4 of 4, by exofreeze
i generally do check the compatibility list. generally you type in the name of a game and dosbox into google and the compatibility list is the first link. didn't come up for me today when I searched.
I'll give the cycle setting a shot tomorrow and see if that works.
