First post, by exofreeze
- Member
Good day.
I received a copy of college slam in the mail yesterday and promptly ripped it to bin/cue format. There are 55 audio tracks on the cd, so bin/cue seemed like the best choice there.
Anyways, I am mounting it in 0.74 using the following:
imgmount d ".\games\CollegeS\cd\college slam.cue" -t cdrom
(I have also tried the older command, -t iso)
I am able to go into dosbox, switch to my d: and install the game.
Launching the game however returns the error:
You need the College Slam CD in your CD-ROM drive!
The game compatibility page states you have to use the ioctl switch, however I was under the impression this does not work with imgmount (just mount).
I can considered copying all the files off the disc and mounting that folder using the ioctl command, but then I will loose the audio tracks. Any suggestions?
Thanks!
