First post, by d1stortion
In this topic some members stated that it is disadvantageous to use an ISA card with newer W95/98 games due to the limitations of the old bus. This made sense to me, but I asked myself what the difference in actual FPS numbers would be. Since I haven't found such a comparison anywhere, I decided to do one myself. The rig I used for this consists of:
Asus P3B-F 1.04
PIII 500 Katmai
V3 3000 AGP (newest 3dfx drivers)
128MB SDRAM
16GB CF card
Win98 SE w/ newest DX9.0c packages
AWE64 Value CT4520 and SB Live! CT4760, respectively.
As a game to benchmark, I settled for Unreal Tournament and its CPU limited utbench.dem (16 bots), which I figured would show the difference between the sound cards best in combination with the fairly weak CPU.
Running at 1024x768x16, all sound settings were left on normal, except for setting 44100 Hz output rate. I uninstalled and unplugged the AWE64 after doing the benchmark on it to go safe. As for drivers, I used the newest ones from Creative Labs in combination with the CDs found in the Vogons driver archive. Damn, enough rambling, now for the results 😁
AWE64: 12.96 Min, 41.61 Max, 27.40 Avg
SB Live!: 11.71 Min, 41.18 Max, 28.91 Avg
As expected the Live is faster, although really not by much. I find it really weird that the max FPS on it is actually lower then on the ISA card... 😳 The results vary a bit from run to run obviously (had 18 min on the Live one time), but all in all, from my testing I can say it's totally not worth switching to PCI just for better performance. Any comments or input on this?
Rerun (PIII@560, V3@184):
AWE64:
1. 16.63 Min, 41.9 Max, 29.27 Avg
2. 12.92 Min, 42.2 Max, 29.58 Avg
3. 19.94 Min, 50.1 Max, 29.61 Avg
AWE64 w/ UseSurround and Use3dHardware:
1. 20.13 Min, 45.81 Max, 29.74 Avg
2. 10.63 Min, 44.13 Max, 29.68 Avg
3. 9.99 Min, 41.77 Max, 29.41 Avg
Live:
1. 15.58 Min, 43.89 Max, 30.37 Avg
2. 12.71 Min, 44.15 Max, 30.56 Avg
3. 12.9 Min, 44.65 Max, 30.55 Avg
Live w/ UseSurround and Use3dHardware:
1. 16.27 Min, 41.89 Max, 28.64 Avg
2. 12.99 Min, 43.91 Max, 28.77 Avg
3. 12.9 Min, 43.96 Max, 28.73 Avg
