First post, by CU_AMiGA
Hi
I currently have an ISA Mach64 graphics card and a PCI Diamond graphics card installed. I plan on using DOS and Win3.1 using the ISA card due to the 3DO Blaster needing an ISA only graphics card and then using the PCI card with Win 98 (along with Voodoo 3D). My question is, is it possbile to have intsalled both graphics cards installed and the same time and confirguring Win98 to ignore the ISA card and use the PCI card and to configure Win3.1+DOS to use the ISA card. I also plan on having Win98 either on a sperate hard drive, or on a different hard drive partition to Win3.1+DOS.
Regards
