The All-amazing super-de-douper SuperPi thread!
Reply 100 of 332, by sprcorreia
One more for the list:
Stock Core i5 760 - 12.667s.
Reply 101 of 332, by noshutdown
k6-2+ @ 133mhz(66*2), gigabyte 5ax 17:30, no match for pentium anyways.
Reply 102 of 332, by Svenne
Just benchmarked my 3dfx-Glide machine that I built a while ago:
Pentium II-400 (4x100), Gigabyte GA-6BXE (Intel 440BX), 512MB (2x256) PC-100 CAS2
6m 20.434s
I'm honestly not too satisfied with the results, seeing as jwt27's PII-350 was about 40 seconds faster.
Intel C2D 2.8 GHz @ 3.0 GHz | ASUS P5KPL | ASUS GTS250 1 GB | 4GB DDR2-800 | 500 GB SATA | Win 7 Pro/Ubuntu 9.10
Reply 103 of 332, by Tetrium
Svenne wrote:
Just benchmarked my 3dfx-Glide machine that I built a while ago: […]
6m 20.434s
What OS are you using? Apparently using 9x results in about 25% slower results or so then when using an NT OS
Maybe we should split the results up?
My retro rigs (old topic)
Report spammers here!
Reply 104 of 332, by noshutdown
thats not essentially the case. win9x results may be less consistant than nt versions, but the performance loss should be no more than 1~2% if you can get it running correctly.
1. optimize your bios settings for performance
2. clean up your windows and load least auto-running programs possible, and don't run any other programs when running superpi
3. for win9x, run some high load applications such as 3dmark or quake to warm it up before running superpi.
Reply 105 of 332, by sprcorreia
Another one:
Stock Pentium D 930 - 42.844s
Reply 106 of 332, by RacoonRider
ASUS P/I-P55T2P4 i430HX 512Kb 64Mb EDO w98se
Pentium 233MMX @262Mhz (75x3.5)
12m. 05.075s.
Reply 107 of 332, by m1919
Dual Pentium 3 Xeon 550/1Mb SL3CE
3m 48.672s
Will retest when I get my Asus XG-DLS board and my dual 700/1Mb Xeons running.
Crimson Tide - EVGA 1000P2; ASUS Z10PE-D8 WS; 2x E5-2697 v3 14C 3.8 GHz on all cores (All core hack); 64GB Samsung DDR4-2133 ECC
EVGA 1080 Ti FTW3; EVGA 750 Ti SC; Sound Blaster Z
Reply 108 of 332, by TELVM
PIII Coppermine 1000/256/133 @ 1127MHz / Tekram P6BX-An 440BX / 768MB PC133 @ 150FSB / WinXP
2m 11.278s
Reply 109 of 332, by senrew
Just for shits and giggles, I ran this with some other stuff open, etc.
AMD A8-3500m @1.5ghz, 8gb ram, windows 7x64
41.499s at 1M
Reply 110 of 332, by [GPUT]Carsten
During normal day work on my desktop-machine:
12.558s 1M
(C2D E8500 @3,8 GHz (400x9.5), DDR2-800 4-4-4-12 2T)
Reply 111 of 332, by RacoonRider
😮 Improved to 10m 48029s. !
Reply 112 of 332, by noshutdown
k6-2+ @ 550 (100*5.5), mvp3 board with 2mb cache:
l3 cache on 5:19
l3 cache off 6:36
Reply 113 of 332, by sebaz_ri
Results from my main rig:
Reply 114 of 332, by TELVM
2m 11.278s
Same system with PIII Tualatin 1400S/512/133 @ 1470MHz / 140FSB:
0.1m 42.387s
Reply 115 of 332, by sunaiac
On my everyday computer : 10.873s (core i7 950 @ 3.83GHz, 166MHz bus, CAS 8 DDR3)
R9 3900X/X470 Taichi/32GB 3600CL15/5700XT AE/Marantz PM7005
i7 980X/R9 290X/X-Fi titanium | FX-57/X1950XTX/Audigy 2ZS
Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
Ppro 200 1M/Voodoo 3 2000/AWE 32 | iDX4 100/S3 864 VLB/SB16
Reply 116 of 332, by maddmaxstar
Cool, haven't been here in a couple months and this thread is still going! If I got time in the next couple days, I'll do a test on my new undervolted mobile-A64 3000+ @1GHz 0.875v.
= Phenom II X6 1090T(HD4850) =
= K7-550(V3-3000) =
= K6-2+ 500(V3-2000) =
= Pentium 75 Gold(Voodoo1) =
= Am486DX4-120(3DXpression+) =
= TI486DLC-40(T8900D) =
= i386sx-16+i387(T8900D) =
Reply 117 of 332, by iulianv
How important are the FSB and the memory for SuperPI? On a 430TX-based board I got around 12m22s with a K6-2/400 (compared to a littler over 9m with an MVP3-based board in the original post)...
One difference is the FSB (my CPU runs 6*66), and then my Win98SE might be running outside cacheable RAM (I have 128MB on my system).
Reply 118 of 332, by m1919
I'm still running my dual 550/1MB P3 Xeons for the moment, until I can swap their heatsinks onto my 700/1MBs, but I am curious to see if there is any difference between the SuperPi run I executed while running my Intel MS440GX board, and the ASUS XG-DLS board I'm now running. Might do another run before I move to the faster processors just to see if there is. Both boards are based on the 440GX chipset, so I'm not really expecting much difference between the two, but who knows?
Reply 119 of 332, by RacoonRider
FSB matters much, but running outside cacheable RAM matters MORE.
My Pentium MMX at 262Mhz and 75Mhz FSB (430HX) gives 10m 37.605s [latest score]. Taking into account that EDO is generally slower than SDRAM, your system's performance is hugely affected by running outside cacheable RAM.
