First post, by Noisia
Good morning fellow gamers!
In the sequence of this topic i'm trying to install GTA London 1969 using the very same procedure. Problem is that the instalation process hangs and outputs this error:
Did anyone attempt this before?
Thank you in advance for your attention!
Reply 1 of 5, by rcblanke
London 1969 also requires xcopy and you need to run the command "set copycmd=/Y" before starting the installation.
Reply 2 of 5, by Noisia
I actually managed to install it using the "SET PATH=Z:\;C:\" and "set copy=/y", all smooth no problems. I play the first mission then i reach the very first cutscene, the game gets REALLY choppy and freezes...
Thanks for that tip! 😀
Reply 3 of 5, by Noisia
Noisia wrote:
I actually managed to install it using the "SET PATH=Z:\;C:" and "set copy=/y", all smooth no problems. I play the first mission then i reach the very first cutscene, the game gets REALLY choppy and freezes...
The cutscenes play well when running low-colour mode. I'm not sure if it has something to do with tweaking the settings in D-Fend, i'm yet to find out.
UPDATE:
There's definitely some sort of "emulation" problem when playing the cutscenes in high colour profile. The only possible solution is to alternate between high colour to play and low-colour to watch the cutscenes with no lags or freezes.
If anyone has a tweak or fix for this problem please let me know! 😀
Reply 4 of 5, by robertmo
have you tried lowering cycles?
Reply 5 of 5, by Noisia
Yes and the outcome is always the same, try it yourself! 😀
