Iam `already`done with this build...
Last changes are:
Swapped the Abit BE6 motherboard for the ASUS P3B-F Slot 1
Swapped the Intel Pentium II 400Mhz to Intel Pentium III 550Mhz one to get more power out of the voodoo 2 SLI setup.
My configuration is:
PROCESSOR
Intel Pentium III 550Mhz 512KB cache SECC2 SLOT 1 ( i dont want to make this system to speedy, because i have a faster system to playing the faster games, it was only pretended to playing games in the
pentium II 400mhz area)
Placed new Coolermaster TS2-5020D2 SECC 2 cooler on the processor, removed the old green TIM ( Before cpu was about 65 / 66 degrees IDLE, NOW with decent TIM 44 to 46 degrees stock)
MOTHERBOARD
Asus P3B-F motherboard (having one ISA slot at the bottom) installed latest 1008 beta bios.. SLOT1
MEMORY
3x 128MB PC100 SD-RAM KINGSTON KT6611/128 3.3V memory = 384MB total
GRAPHICS
Diamond VIPER V770 32MB AGP
GLIDE
2x Creative Voodoo 2 12MB SLI ( i did it for higher resolution 1024x768)
NETWORK
3COM PCI (just for the sake)
SOUND
Creative SB LIVE! CT4620 with the PCI bracket expension CT4660
HDD CONTROLLER
Because the motherboard doesnt support UDMA66 i installed a promise fasttrak S150 TX2 PLUS (using the IDE port only)
OPTICAL DRIVES
Primary Master : Toshiba DVD-ROM SD-M1502
Primary Slave : LG CD-ROM CRD-8521B
HARD DRIVE
WDC WD800BB-55JKA0 80 MB Ultra DMA 5 / IDE BUS master enabled
