First post, by TomSL
I am trying to replace some ancient hardware hosting a
single DOS 6 proprietary application. The application
has some custom hardware which emulates an AT
keyboard for button presses. When I hook this keyboard
to a Win XP machine, it works fine in XP (e.g. to notepad
or a command prompt). When I run MS-DOS 6.0 which I
installed in dosbox 0.74 running on the same XP machine,
a single press of a key results in a continuous stream of
the same character sent to the DOS 6 prompt until I press
a different key, at which point I get a continuous stream
of the new character. (1 character, a slight pause, then
continuous more of the same - typematic style)
If I click away from the Dosbox window
and activate a different XP window the keyboard again
works properly.
Somehow XP sees the single key press correctly, but
when passed to dosbox, it is seen as being held down.
Additional info: it works correctly in bochs, and in
VirtualBox, but has the repeat problem in VirtualPC 2007.
Any ideas?
I am willing to pay/donate to someone who can fix this problem!
Thanks,
Tom
Reply 1 of 9, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
I think there are some stuff you can do:
Try yhkwongs SVN build or any SVN build
Try different output in the dosbox config
And/or set sdl to use windib or not use windib (do a search here for windib for instruction).
If any of this works, please donate $2 to the dosbox devs 😉
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 9, by ripsaw8080
Rank DOSBox Author
DOSBox Author
I am not certain of the exact cause of the problem, but you may find some guidance here:
dosbox keyboard problem
Reply 3 of 9, by TomSL
Thanks Dominus. Some of that is over my head. What do you mean by
'try different output'. I will try the windib change. I'm willing to donate much more than $2 for a specific
fix.
Thanks ripsaw, but that thread mostly lists a lot of voodoo with no specific fix. Lacking a better
answer, I guess I'll try the voodoo.
Reply 4 of 9, by Dominus
DOSBox Moderator
I guess you are on Windows, then the installer added a shortcut to your startmenu (in a dosbox folder) called "edit config" or similar (it's been a while since I was using Windows). Click that and your dosbox config will be editable with notepad. You will notice several groups of settings, in the first obe you can find the output setting and a bit higher up the possible values
Reply 5 of 9, by TomSL
OK, I permuted through all the output options (surface, opengl, openglnb,overlay) (why would output options affect keyboard input??) ) - no change.
I tried SET SDL_VIDEODRIVER=WINDIB (though I was unclear where, so I tried in the config file and in the Xp cmd prompt)
Also tried SET SDL_NO_RAWKBD as above. in config file no help. In cmd prompt, errored as undefined, so I tried
SET SDL_NO_RAWKBD=TRUE and =FALSE, but no change.
Please forget your proposal of a $2 donation. I will happily pay $100 donation/fee for a proper precise fix.
thanks,
tom
Reply 6 of 9, by Dominus
DOSBox Moderator
When you set some sdl stuff on the cmd prompt (which is the way to go to test stuff, to permanently set this you'd use some Windows setting), you will have to start dosbox from that prompt as well. If you did this, then I'm out of ideas.
Reply 7 of 9, by ripsaw8080
Rank DOSBox Author
DOSBox Author
A precise fix for a problem requires the precise cause to be known.
That said, does this repeating key problem happen in DOSBox's shell, or does it only happen after booting into MS-DOS 6?
Reply 8 of 9, by TomSL
Dominus: yes, I started dosbox from the same command prompt in which I had set the variables.
Ripsaw: while the original hardware and disk boots dos6 then runs the app, under dosbox i simply mounted a copy
of the original drive as C in dosbox, then ran the app. (dos6 files are there, but it's not clear they are ever touched.)
Dosbox seems to provide a 'DOS' natively. So i'd say the repeating appears in the dosbox shell. Is there a way I should run my copy of dos 6 within dosbox? How would this work?
seems like dosbox config leaves off at launching an autoexec (if configured), not booting an OS. What does it mean to run dos6 within dosbox?
The native PC hardware running dos6 doesn't have this problem - I don't know if it's a difference in the emulated BIOS
or emulated DOS. If the latter, maybe booting dos6 will fix it. How do I boot a dos6 within dosbox?
thanks again,
tom
