First post, by emendelson
Hello,
Once again I think I'm missing something obvious, and would be grateful for any help.
I have no trouble building SVN with Visual C++ 2010 Express, using SDL-1.2.14.
Today I downloaded the visual C source for SDL-1.2.15, and placed in my Development directory, right next to SDL-1.2.14.
I opened my SVN project in Visual C, and went to Project/Properties, and then went to Configuration Properties/Linker/General, and edited the Additional Library Directories. I changed "../SDL-1.2.4/lib" to "../SDL-1.2.5/lib/x86" since I saw that the directory structure now included X86.
I clicked Apply, OK, etc., cleaned the project, and tried to build, but I got the fatal error "cannot open the input file 'sdlmain.lib'.
So I copied the three SDL files from /lib/x86 into /lib, went back to the Configuration Properties, changed the additional folders back to ../SDL-1.2.5/lib and tried again. Same fatal error.
I'm still using sdl-net 1.2.7, if that makes any difference.
Clearly, I'm doing something wrong, but I can't imagine what it might be. Once again, I'll be grateful for any advice.
Reply 1 of 5, by bloodbat
Did you build SDL yourself? Also did you build SDL_net?
If yes to both, it's probably a good idea to rebuild SDL_net against your new SDL; also, when I built SDL 1.2.15 the files ended up in different places, namely SDLmain had its own subfolder appropriately named "SDLmain" and the library file was compiled under there, so you may want to check that.
Reply 2 of 5, by emendelson
No, I didn't build SDL; I did exactly what I did with 1.2.4, which was to download the Visual C "development libraries" from this page:
http://www.libsdl.org/download-1.2.php
As I said, the same thing works perfectly when I have 1.2.4 in the additional directories, not 1.2.5.
Visual C++ says it can't open the file, which makes me wonder whether it can find the file. But the "command line" option in Visual C++ seems have a correct libpath= parameter, pointing to 1.2.5, just as the properly-working setup has a command line pointing to 1.2.4.
Reply 3 of 5, by bloodbat
Ahh I see now...you did change the include path to the new one too, right?
Reply 4 of 5, by emendelson
Ah - you're right: in the Property Pages, under Configuration Properties, C/C++/General, in the "Additional Include Directories" I forgot to change
../SDL-1.2.14/include
to
../SDL-1.2.15/include
But now that I've done that, and cleaned the solution, I've given myself another problem. The build output gives a fatal error:
d:\development\dosbox with char9\include\timer.h(23): fatal error C1083: Cannot open include file: 'SDL.h': No such file or directory
Of course SDL.h is in ../SDL-1.2.15/include.
I'm sorry to come back to you with these beginner questions, but if you can guess something else I need to do, I'll be grateful. Obviously, I got this right once, and am only hoping to figure out how to get it right again.
Reply 5 of 5, by emendelson
OK - PLEASE IGNORE EVERYTHING I WROTE EARLIER - and many apologies for wasting time and bandwidth!
It was a stupid beginner's mistake - I put the SDL 1.2.15 directory one level above where it should have been. I saw an SDL 1.2.14 directory and put the 1.2.15 directory next to it - when I should have looked one level down, where I would have found another 1.2.14 directory and should have put it there.
Heartfelt and deep apologies again for wasting other people's time and the board's bandwidth. This really was something I should have figured out for myself instead getting other people to explain to me that 2+2 does not really equal 22.
