Dosbox CPU option
First post, by luktom100
Hi there, leately when i was checking dosbox config. file, ive noticed that you can chose CPU core and turn up the cycles, then i was started to wondering. Is it possible to overburn your CPU or break it when you have old PC while using this Config options ??
Reply 1 of 3, by leileilol
No. It'll just go into slow motion.
Reply 3 of 3, by Freddo
DosFreak wrote:
DOSBox is just like any program, if you have improper or faulty cooling then any CPU/GPU intensive program can harm your computer.
Yeah, software can't use more than 100% of the hardware, no matter what. It's then up to the cooling to be able to handle the heat from the 100% workload.
