First post, by alban lusitanae
If so, how do I do it?
The reason is: I'm doing a Portable Multi-Platform Playstation project (PMPP)
thx for all the help in advance
Alban
Reply 1 of 3, by Mau1wurf1977
What I use is D-Fend Reloaded in portable mode. D-Fend Reloaded is a Frontend and it ships with DOSBox. During the installation just select custom and then portable mode and point it to the USB Flash Drive.
My YouTube channel
Reply 2 of 3, by alban lusitanae
So run the install of DFR and it uses DB. Which DB is it using? Also, does it keep its stance if the drive where the USB PEN is is not E but F or G for example?
