First post, by ratfink
I'm wanting buy a front panel for fan control. Some allow up to 30w per channel, some only 20w.
I can't believe cooling fans take even 20w, but can anyone advise? I somehow doubt it will be stamped on the fans I have.
Actually it is marked on the fans, albeit indirectly. (Assuming the labels haven't been peeled off.) Take the amperage and multiply it by the voltage, and you've got wattage.
I better have a closer look in thta case, thanks.
sometimes, there are brand name labels applied over the original fan maker/spec sticker... you may want to see if that is the case
wrote:I somehow doubt it will be stamped on the fans I have.
20W would be 1.67 A
30W would be 2.5 A
These would be INCREDIBLY loud and powerful fans. Even server grade 120mm fan don't crack 1.3 A
Some of the fans they use in Dell Optiplexes are 2 or 2.5A. They're loud as hell when they ramp up to full speed, but also move a fair bit of air quietly at lower speeds. Of course they also draw less power at lower speeds, but when using such a fan with a speed controller, you'd still want to go by the maximum power rating just to be safe.
I'd be using the controller for my socket A dynatron fans. Only small fans but they run at 7000rpm. Deafening and no need for such high rpm.
is there any good fans 'benchmark' site out-there ?
Power usages,
Noise decibels,
Airflow volumes,
Cooling capability,
etc..., etc....
-fffuuu
IMO, Sanyo Denki fans are the best
I haven't have one fail on me yet.... I still have ones working perfectly after buying them 10 years ago, run 24/7... they're far from quiet compared to today's fans, but I'm sure they now make quiet fluid bearing ones... in any case, they're industrial grade and used by many OEMs
wrote:is there any good fans 'benchmark' site out-there ? […]
Power usages,
Noise decibels,
Airflow volumes,
Cooling capability,
etc..., etc....
X-bitlabs have been doing the larger ones (120mm~140mm) over the years:
http://www.xbitlabs.com/articles/coolers/disp … -roundup-2.html
http://www.xbitlabs.com/articles/coolers/disp … -roundup-3.html
http://www.xbitlabs.com/articles/coolers/disp … -roundup-1.html
http://www.xbitlabs.com/articles/coolers/disp … an-roundup.html
http://www.xbitlabs.com/articles/coolers/disp … ns-roundup.html
