I generally capture with my VGA capture card directly from the real hardware and not from Dosbox, so can't help with the settings within dosbox, but I think there are some general topics I can speak about:
Great Hierophant wrote:1. How can I losslessly convert the video, which uses ZMBV codec, into something friendly to streaming video? Is there a freeware program that will work?
Can't answer this question unfortunately, as I use Sony Vegas to do that job for me with the excellent built-in MPEG2 and H264 codecs. I know VirtualDub can do conversion very good, but it's not exactly user friendly.
Great Hierophant wrote:2. For 16:10 videos, how can I add black bars on the top and bottom to keep the aspect ratio? My concern is that any video conversion to convert 320x200 into a 4:3 ratio, like 640x480, will introduce artifacts of some sort. Playback on a CRT with an adjustable vertical size control should allow someone to properly stretch out the video.
If the stretching is done properly, nobody will notice. A 320x200 image is stretched vertically on a 4:3 monitor to match 1.33 ratio, so to present the game properly, you have to do the same. Then again I'm unsure if Dosbox already does this for you when capturing.This video (showing that the Gamebroadcaster can capture unsupported resolutions) shows me using stretch function in Sony Vegas from the original capture resolution to represent a 4:3 image.
Great Hierophant wrote:3. 70 FPS is very unfriendly to streaming video services. Is there a way to force DOSBox to redraw the screen at 60 or 30 FPS (with a VESA utility)? I would prefer DOSBox to do it instead of an external program, which will undoubtedly introduce loss into the video quality.
70 FPS I have no experience with, but atleast aim for 60FPS when capturing. Don't you think Youtube will be offering 60FPS in their videos very soon? I capture and render all my videos in 60 FPS. I'm very sure Youtube and other streaming services will support it very soon, just like they did with widescreen, 1080p, 3D, subtitles, etc etc. Also Youtube do a good job on the 60 to 30 FPS conversion, it's not something people will notice unless they know what to look for.
