First post, by Holzwurm56
We start DosBox from an Win7 Program with a Batch-File to start an old compiler and it works very good.
At WinXp (32Bit) the compiler works direct with the XP without DosBox and we configured that the user doesn’t see the compile process. It were running behind.
With DosBox we see every time the DosTask in the TaskBar and the Windows pops up. Is it possible to configure DosBox that we see nothing from the DosBox?
Thank for all post
Holzwurm
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
dosbox is intended to be seen. It is an emulator for games.
Water flows down the stream
Reply 2 of 4, by Jorpho
I assume he is referring to the console window.
The console window can be hidden by adding "-noconsole" to the shortcut you use to launch DOSBox.
Reply 4 of 4, by mr_bigmouth_502
Minimize it! 🤣
