First post, by sliderider
- l33t++
http://www.cpu-world.com/Compare/988/AMD_Athl … empron_150.html
Athon64 FX-57 vs Sempron 150
I think the Sempron 150 would be faster because it is a K10 generation chip and Athlon FX is only K8 so it is on a smaller process and supports newer technologies. The raw clock speed of the Sempron is 100mhz higher out of the box and because it's made on a smaller process, it would likely overclock better. They both have the same size caches. The Sempron can be mounted in a socket AM2+/AM3 motherboard so it would support DDR2 vs the FX-57 which is Socket 939 and only supports DDR.
So on paper the Sempron looks like it beats the FX, but sometimes paper specs don't always tell the whole story. So which do you think is faster? Would the Sempron 150 be the ultimate chip for running Windows 98SE?
