MS Dos configuration
First post, by Stojke
Does any one have an tutorial on properly configuring MS DOS 6.22 install?
On the German DOS i could chose how do i want to start the system:
1) With EMS
2) With out
3) For CAD - something
And when i chose the EMS function before starting the computer scanned for EMS and did a few other checks. Loaded Mouse drivers, CD ROM drivers, sound blaster and some other things. After which it did a root scan with McAfee 1996 and displayed active partitions and something else.
What is the most important to me is a functional EMS which i still dont know how to configure properly.
Can any one direct me to a tutorial on a proper memory extender and how to install it onto a fresh DOS 6.22/7.10 install?
Btw, I've backed up the hard drive into an ISO if any one needs some file or something.
[Edit]
Id also like to use both my GUS MAX 2.4 and SB16 in the PC, if some one would please tell me how to configure that as well. I installed both cards, but in monkey island it only plays on SB16. And when i set it to roland there is no sound at all.
Reply 1 of 2, by elianda
in config.sys
1)
DEVICE=C:\DOS\HIMEM.SYS
DEVICE=C:\DOS\EMM386.EXE
2)
Youtube Channel
Reply 2 of 2, by Stojke
Oh i see now, I've analyzed the German system config.sys as well, thanks! 😀
