First post, by elianda
- l33t
Hello Vogons,
I just did a session to compare various DVD accelerator solutions (may be extended later).
I recorded a brief footage from the 5th element movie that shows some slow moving scenes in the beginning with fine structures on the book and in the end some faster scenes with higher brightness dynamic.
You will see also the interface of the players briefly. They are specific for the used DVD accelerator solution. Some allow to playback also mpeg2 files.
The system I used was a P2 233MHz on a 440LX chipset (MSI-6117 board) with Win98SE.
1)
i740 AGP 8 MB SDRAM with Sigma Designs Malibu daughterboard with Realmagic EM8220 2MB, SB16
graphics mode 1024x768 24bit color depth
Richard already posted photos of it here:
http://homepage.ntlworld.com/p.birch73/richar … vogons/card.jpg
http://homepage.ntlworld.com/p.birch73/richar … /db_removed.jpg
Comparison Video footage: https://retronn.de/ftp/videos/dvd_decoders/si … i740_em8220.mkv
my notes:
The decoder seems to have problems with the format of PAL 4:3 resolution.
If the movie is 16:9 with less vertical lines it seems to work.
Audio sounds as if capped with a low frequency.
Conversion Quality Setting in Windows was set to high though.
The daughterboard is mapped through the i740 resources.
2)
Creative PC-DVD-Encore Dxr2
Matrox G200, SB16
The card: https://retronn.de/imports/hwgal/hw_creative_ … dvd_ct7120.html
Comparison Video footage: https://retronn.de/ftp/videos/dvd_decoders/cr … encore_dxr2.mkv
The Dxr2 uses a VGA Loop Through cable and uses analog chroma keying.
This also reduces the normal vga signal quality
I didn't recorded audio, but you get german subtitles instead.
The average dynamic of the video playback is rather bad.
The decoder chip has problems with PAL resolution that have more vertical scanlines.
It is not as corrupted as the Malibu daughterboard but the lower part will be cut off, including subtitles.
The card uses I/O and an IRQ.
The Dxr2 has SPDIF out, so I didn't record audio from it. As it is digital no quality loss is expected.
3)
Quadrant CineMaster C3.0
Voodoo3 3000 AGP, SB16
graphics mode 1024x768x32 bit
the card: https://retronn.de/imports/hwgal/hw_cinemaster_c3.html
Comparison Video footage: https://retronn.de/ftp/videos/dvd_decoders/qu … emaster_c30.mkv
The CineMaster card uses a VESA feature connector cable for rendering to the graphics cards framebuffer.
It didn't seem to work on a Matrox G200A (crashed in 24 Bit and reported unuseable mode for 16 and 32 bit color depth)
Audio was routed from the CineMasters analog Audio-Out to SB16s Line-In.
Still you will hear a difference compared to the Malibu daughterboard f.e.
DVD Menu seems to be slightly corrupted on top. Crackling of Audio in the Menu is gone if the movie starts.
Tried also "Serenity" DVD, where Menu is also corrupted and showing just a few scanlines of it in the upper area.
Audio does not crackle in menu.
If it works the video quality is better than with the other solutions.
Overall: It was quite a hassle to get the cards running. Sometimes it simply doesn't work, i.e. system freezes when starting playback. DVD player crashing, no video just sound or no sound just video or the graphics card does not work together with the accelerator card...
The system was tested before for stability and everything else worked fine. Most of the player applications seem to have been never updated. The accelerator card support was probably dropped as soon as the average PC could play DVDs by software.
4)
ATI Rage 128
Ati Rage128 AGP 90 MHz (powerstrip), SB16
graphics mode 1024x768x32 Bit
the card: https://retronn.de/imports/hwgal/hw_ati_rage128gl.html
comparison video footage: https://retronn.de/ftp/videos/dvd_decoders/ati_rage128.mkv
Ati DVD Player 3.2.0.1
Rage128 driver 6.01-CD68-1C
The Rage128 added IDCT acceleration support (inverse discrete cosine transformation)
(the Rage II had just Motion Compensation)
While the official requirement check at the installation of the DVD player warns that it recommends a P2 300 MHz
the DVD playback runs pretty well on the P2 233 MHz. Quality is also good.
There is a stutter near the end, but the dvd was mounted over network using a rather cpu hungry realtek network card.
I tried from HDD and the system kept being responsive, so with a real DVD drive in DMA mode it should run even better.
Maybe even a lower end CPU is able to play DVD with a Rage128.
The latest driver for the Rage128 did not work, so I had to install an older one.
DVD Menu worked, no problems with PAL resolutions.
DVD player supports playback of mpeg2 files.
I was quite a bit surprised that it runs so well.
5)
ATI Rage Pro Turbo AGP
Ati Rage Pro Turbo AGP, SB16
the card: https://retronn.de/imports/hwgal/hw_ati_rage_ … turbo_agp2.html
(image similar, I used one with memory expansion and of course enable int jumpered)
comparison video footage: https://retronn.de/ftp/videos/dvd_decoders/at … e_pro_turbo.mkv
Quality is good. There is rarely a stutter in sound playback but overall ok.
I used the same driver package as for the Rage 128.
Not much to say here, it just plays on the P2 233 MHz.
6)
ATI RageII+DVD PCI
Ati RageII+DVD PCI 4 MB EDO 60 MHz, SB16
graphics mode 1024x768x24 Bit
comparison video footage: https://retronn.de/ftp/videos/dvd_decoders/ati_rage2dvd.mkv
I used the same driver package as for the Rage 128 from ATI driver CD 6.01.
DVD Menu worked, no problems with PAL resolutions as with the other ATIs.
I had to lower the color depth to 24 bit at least, since it stutters at 32 bits.
This seems to be a bug as it appears also with faster CPU clocking.
The quality is average, no postprocessing at all, you can nearly see the decoded pixels.
Note also f.e. the red line when the starship is first shown.
After seeking it needs some seconds until audio and video is in sync again.
Overall it seems already very CPU limited at 233 MHz and frame rate of the playback looks reduced.
Something else I noticed is that in 16 and 32 bit color depth 2D-GUI acceleration works, but not in 24 bit, as you see
when I move the window.
With an ATI RageIIC AGP (without +DVD) the ATI player refuses playback.
7)
Matrox Marvel G200-TV with DVD Upgrade Module
the card: https://retronn.de/imports/hwgal/hw_Matrox_Ma … DVD_module.html
comparison video footage: https://retronn.de/ftp/videos/dvd_decoders/ma … _dvd_module.mkv
Matrox G200 AGP + DVD Upgrade Module (G2+/MVA/8I GS/DVDMOD/I), SB16
Matrox DVD Player (internal Ravisent 2.0) (Found thanks to a lost disk from NJRoadfan)
Quality is good. No issues. Not even driver/crash issues.
I wonder if a Realmagic Hollywood Plus tops this quality.
If I get a VGA Loop Through for the Creative dxr3 done I can add it too.
Youtube Channel
