First post, by SquallStrife
- l33t
This will be in the next Retro Swim (which will be about my IBM PC) but here's a sneak peek!
I got this monochrome monitor off DonutKing. He said it had white phosphors, but he hadn't used it, so he couldn't say whether it was working or not.
Here's the beastie:
So I hooked it up to the IBM PC. Power LED came on, and I could hear the HT working, but when it warmed up it looked like this:
I opened it up to look for any obviously bad components, failing to notice any, I took the PCB all the way out to get a closer look and noticed a huge crack in the PCB:
I used some wire from an ethernet cable to join up all the traces that lead over the crack.
And now it works a treat!
