First post, by Caine123
i got this game as retail boxed from the past and when i start the game it starts until i want to start a new game then it crashes. win7 64bit.
any fix for that?
does the gog.com version work without probs under win7 64 bit? then i would maybe buy it there before going through trouble with the retail version...
Reply 1 of 9, by leileilol
Did you try it with a glide wrapper like nGlide?
Debian's fucked
Reply 2 of 9, by Caine123
no not yet, i got a ATI card and dunno about nGlide, where can i set this?
Reply 3 of 9, by Jorpho
You should check the official GOG.com forums for the game. Several games on GOG.com require a glide wrapper in order to run properly.
http://www.zeus-software.com/downloads/nglide
Reply 4 of 9, by Gamecollector
No glide API in this game.
Try to run the game as "go.exe -nocputest".
Plus, IIRC, the original version is protected with Safedisk 1x, so - you need administrator rights in Win7 to make it work correctly.
Reply 5 of 9, by Caine123
where do i write the "-nocputest"?
Reply 6 of 9, by Davros
create a shortcut to go.exe (if you dont have one)
right click -- properties -- target
Reply 7 of 9, by Caine123
great this worked but does someone know:
1. how to save the graphics options? when i run expendable.exe and setup it always resets the option.
2. how to convert the music? i want to listen to it outside expendable 🙁
3. how to turn up the volume of the music without the sound effects, it's very quiet in game.
Reply 8 of 9, by kolano
1. I'm guessing the game isn't compatible with the concept of not being able to write to files within "Program Files". Try running it as an administrator, which should enable it to update the files it needs to.
Not sure about 2 or 3.
Eyecandy: Turn your computer into an expensive lava lamp.
Reply 9 of 9, by Davros
installing the game to c:\games\expendable will make things easier for you
