First post, by Totempole
- Member
So I recently got hold of the above card, and was hoping it would be an
somehow be an improvement over my existing TNT2 M64, but up to now
I haven't found anything that makes the 3DFX card better than the TNT2 M64.
First, Drivers (Win98SE) obtained from http://www.falconfly.de:
I started with the 1.07 Drivers, which were terrible. Nothing seemed to work
with them, not even the standard DirectX Direct3D test.
Then 1.03 drivers. These seemed to offer the best performance, but I had
some issues with installing games. i.e the "Next" Button would disappear
Finally, 1.05/1.06 Drivers. These seem to work properly with this particular
card.
Games I tried:
First, Need For Speed 2SE: Game only ran in Directdraw mode. I assume
3DFX support was only for earlier 3DFX cards.
Croc 1, Rollcage and Rollcage II: All of them looked almost exactly the
same in Glide as it does with the TNT2 in Direct3D.
Finally, MDK2. In-game textures looked very crisp, but menus and
cinematics are all pixelated.
By now you've probably figured out this is the first 3DFX card I've
ever owned, so I don't know much about them.
So here are the questions I have for people that know these cards well:
1. Which driver do you recommend?
2. Which DirectX version should I be running?
3. Are there any 3DFX exclusive games out there, or games
that would look significantly better on the 3DFX than the TNT2?
4. Is there anything else I should know about this card?
Thanks in advance for any responses.
