First post, by nforce4max
- l33t
http://en.expreview.com/2012/10/26/amd-fx-835 … 6ghz/24814.html
Not bad for all 8 cores.
I'm confused by this, I think that is a new CPU so slow of speed?
Doom isn't just a game, it's an apocalypse survival simulator.
Slow?
Ghz, dosquest, not Mhz 😀
Wow..I feel silly now...also my sentence structure must of been killed by my iPad 🤣
but will it run crysis?
when 2036 rolls over, "Will it run crysis?" is going to be a big fat no when the 64-bit version of Crysis doesn't even work.
...in 2036 people will be coming to this forum asking "hi can I run crisis 1 in windows 16" and all the "retro games" will be like metro 2033 and crisis.
in 2037 windows9quest will bump this thread
Yaay necropotising ftw!!!!!! Yeah -_-
On a side note, did you really get your avatar removed lel? Damn that one was around for years, are the mods getting too picky now?
wrote:On a side note, did you really get your avatar removed lel? Damn that one was around for years, are the mods getting too picky now?
You didn't consider the possibility that the lei changed it ?
Water flows down the stream
I never understood the point of these extreme overclocking experiments. I would think that the fastest overclock that you can get away with and still use the machine on a daily basis would be a whole lot better than 8ghz on liquid nitrogen, something that you would never be able to actually use for more than a few minutes at a time without spending a ton of money on coolant or destroying your CPU/motherboard.
I would be much more impressed with a much lower speed that is actually usable mounted in a case using high performance air cooling or even a liquid cooling system that is readily available to most people.
for the same reason Guinness World Records exists.
