First post, by Filosofia
Thinking about getting a laptop for dos gaming and some K6-2 based Toshiba Satellite laptops caught my eyes, but I don't know if they have the option to disable L1 and L2 in the BIOS, which would be decisive. Can someone confirm this for me? Thanks 😀
Also managed to get a picture of the particular model with a 475MHz unit, I worry about it being soldered because I might need to downgrade it in order to avoid RTE200
BGWG as in Boogie Woogie.
Reply 1 of 2, by Mau1wurf1977
You don't need the option, as you can turn off L1 through a DOS command line utility 😀 I have to do this on one of my machines, it only has an L2 BIOS option. It's called ICACHE.EXE and I can upload it if needed.
I have tested it on a K6-2 and K6-2+ and also Pentium.
If there is no option for L2, then you can only turn off L1 (AFAIK I don't know about a software tool for disabling L2). In terms of slowing down this means you will end up with the speed equivalent of a 486DX to 486DX2 depending on FSB and factors such as RAM timing.
My YouTube channel
Reply 2 of 2, by Filosofia
Thanks, that is solved then 😎
Does it look soldered to you?
