Run in Android
First post, by mperelman
Can I install DosBox in Android? Can I use an installed keyboard with function keys.
Thank you very much.
Michael
Michael Perelman
Economics Department
California State University
Chico, CA
95929
530 898 5321
fax 530 898 5901
http://michaelperelman.wordpress.com
Reply 1 of 3, by eL_PuSHeR
[Thread moved to DOSBox General Section]
Reply 2 of 3, by Xelasarg
Check the Play Store. Hint: aDOSBox is free, but runs like crap. 😉
"What's a paladin?!"
Reply 3 of 3, by ariqu
There are a few builds of DOSBox on the market, one of which is aDosBox. The others, if I remember right, are not free. AnDosBox and DosBox Turbo are available and work to some extent, depending on your device.
If the keyboard you are referring to is physical, it may work, depending on the IME. If you have a full keyboard layout IME (like Hacker's Keyboard), it will work, function keys and all.
