First post, by BenjaminSisko
Hi Need some help to get TR1 working in fullscreen Mode.
Everything works perfectly in windowed mode. however if i set fullscreen Glidos crashes after the initial FMV,s have completed.
I tried using OpenGL mode but that results in repeated "Screen Mode Change Failed" error popups.
In direct 3D (voodoo), glidos crashes after FMV's which work fullscreen.
I'm running Windows 7 Home 64bit with 8gb memory.
My version of TR1 is original 2 CD TR1+Unfinished Business, I also own a Mastertronic dvd boxset of the 1st 4 TR games, tho have not attempted to play these yet.
Any help apreciated
Thanks
Reply 1 of 5, by Glidos
Are you using the FMV pack? Also, which version of Glidos?
Reply 2 of 5, by BenjaminSisko
Yes i'am using the FMV pack and the latest Glidos v1.52.
The game would not run fullscreen before i installed the fmv pack or with the setting to not use the fmv pack.
Tho the crashing started after installing the fmv pack, before i just got the "screen mode change failled" error.
note the fmv play fine fullscreen, error/crash occurs after initial fmv's have finished.
Reply 3 of 5, by Glidos
Do you have "Inhibit mode change" checked?
Reply 4 of 5, by BenjaminSisko
ok thats fixed it, now fully working, the actual game screen is still limited to the preset resolution surrounded by black borders.
But i can live with that 😎
Thank you very much for an exellent tool 😁
Reply 5 of 5, by Glidos
Coo, I'm glad that worked because I have no idea what's causing the crash.
