First post, by Stekahedron
Motherboard = ACPI x86 based PC
Processor type and speed = Intel Atom CPU N455 at 1.66 ghz (dual)
Amount and type of RAM = 1.00 GB
Video board w/ RAM amount and type = intel graphics media accellerator 3150 250mb
Sound board = realtek high def audio
Operating system = windows 7 (starter)
Game name (and version, if applicable) = Jagged Alliance
Hi all the intro sequence plays fine, sound is fine, but the new game screen is messed up and after that it gets a bit sketchy, the intro with the old man and his fit daughter was ok but now doesn't run. The credits run and then the intro is ok aswell. Anyway then the game doesn't run
I've tried to change display output, ems, xms, vga only options but i aren't getting anywhere, any ideas?
Regards
Reply 1 of 7, by Stekahedron
no takers? Have i missed summert out?
Reply 3 of 7, by Stekahedron
I have installed to D:\ via daemon from an ISO ---- should I mount a cd drive in dosbox which corresponds to the daemon ISO?
Reply 4 of 7, by bloodbat
Yes. DosBox doesn't care for anything you don't mount.
Reply 5 of 7, by Stekahedron
thats great, i clicked as soon as i read your post.
I do have a second problem now... it seems that whenever in gunfight mode with enemy soldiers the game plays sluggishly occasionally, and then crashes also... a whole screen of text runs down the graphic interface and the secondary dosbox reads "X86 cannot run program"
Any ideas?
Reply 6 of 7, by bloodbat
To fix the sluggishness you probably want to adjust the cycles. The error...I don't know.
Reply 7 of 7, by Stekahedron
I'll see what I can do, the locking and crashing takes various forms, thanks for all your help
