ems is not working
First post, by gast
hi
i've got the same problem with tie fighter
i used the go.bat and he don't even list EMS.
XMS is always available. can i use XMS as EMS?
what should i do?
Reply 1 of 4, by gast
oh i forgot to show you my system
i've got an athlon 2100+
asus a7n8x
2*256 samsung ddr ram
creative adigy player
ati radeon 9600
usb mouse
usb joystick
and winxp prof running
my problem is caused by the hardware i use.
but how can i solve the problem???????
Reply 2 of 4, by eL_PuSHeR
If a game support both XMS and EMS, i would go with XMS first.
Reply 3 of 4, by Harekiet
Rank DOSBox Author
DOSBox Author
use other hardware?....
Reply 4 of 4, by vladr
Try to disable from the BIOS any stuff you may not be using under pure DOS and has drivers under Windows (such as onboard RAID controllers, SCSI cards, or support for USB mice and keyboards.) Regions in memory are allocated by the BIOS for these things in order to support real DOS, but WIndows already has drivers and the regions allocated in memory (which interfere with EMS) may in most cases be redundant.
V.
