First post, by gabbyjay
Sup all, I recently rebooted an old FMV game that's near & dear to my heart called The Dame Was Loaded. Got up to the end of disc 1 and was given the prompt to "please insert disc 2"
I've set Dosbox to run off the CD-Rom drive, assigning d: to /Volumes/DAME_CD1 -t cdrom -label DAME_CD1
Once I get to the end of the CD, I'm stuck. The eject key won't work, since the program is in use, and even if I could insert disc 2, the directory name is changed to "DAME_CD2", so the program would probably crash due to the name change.
I tried dragging and dropping the files off the CDs into separate folders, but couldn't seem to get the game to boot without using a disc. Maybe I'm leaving something out.
What are the normal methods you guys use for games with multiple discs? Anyone have any advice? Would be much appreciated. =)
