First post, by northernosprey02
Which is better?
Seagate U10 or Quantum Fireball lct 10?
Reply 1 of 7, by leileilol
That's like asking if a Deathstar is better than a Maxtor!
Seagate.
Debian's fucked
Reply 2 of 7, by luckybob
flip a coin.
Reply 3 of 7, by elianda
Both are low end drives, the Seagate is a more modern generation of drives and approx. twice as fast.
The rubber shock protection bikini of the seagate drive might have some appeal... ...or maybe I was just distracted by some avatar thumbnail 😉.
Youtube Channel
Reply 4 of 7, by northernosprey02
I am wondering what for rubber cover. Is it can reduce noise?
Reply 5 of 7, by Old Thrashbarg
Theoretically it should reduce noise somewhat, but I really never felt it made much difference... I've used drives with and without the rubber thingy installed, and it muffles the seek noise a little bit, but it doesn't really have much effect beyond that. You'd probably be as good or better off just using rubber washers between the drive and case when you mount it... that'd give you some acoustic isolation without blocking ventilation to the drive.
IIRC, the Quantum drive was a little faster on seeks, and the Seagate was a little faster on transfer rates. Neither is particularly fast though. The Quantum LCT series seem to be pretty reliable... I've not really run across many dead ones, and I've got a couple dozen around here that all still seem to be as good as new, even though most of 'em were in everyday service for the better part of a decade. I can't really comment on that Seagate series, since I haven't run across more than a handful of 'em.
Reply 6 of 7, by northernosprey02
Which is good HDD for new retro rigs?
Maxtor or Conner?
Reply 7 of 7, by Hatta
IMO, CF-IDE for anything really old. For anything even halfway modern a SATA-IDE adapter or a PCI-SATA controller and a modern drive. You can find SATA controllers with Windows 98 drivers.
Hard disks really don't need to be period, it's just storage.
