First post, by exofreeze
I imaged my game disc for this game and installed it via 0.74. However, at the main menu when i choose to start the game, it tells me there is no disc in the drive.
i used clonecd to make the image, however I don't know if something in the header file (ccd) is required for the game to see a proper disc label, or something along those lines.
I am using the following mount line:
imgmount d .\games\Drilling\cd\billy.img -t cdrom
Reply 1 of 1, by ripsaw8080
Rank DOSBox Author
DOSBox Author
CloneCD will create a CUE file in addition to the CCD file, but maybe it's an option. I'm surprised mounting the .IMG worked at all without a cuesheet; only ISO format is supported without a cuesheet... Anyway, try seeing if you can get CloneCD to give you a CUE.
