First post, by Shodan486
It's been a while since I tinkered with my beloved 486 rig. I wondered what I could optimize or upgrade in it, so I took a glance here and there @ VOGONS, which always makes me to do some stuff.
Just to elaborate graphically:
I've made several changes to the setup, will be explained below soon
Mobo: Asus PVI-486SP3 / Rev. 1.2 / BIOS - 0307
CPU: Am5x86 133MHz ADZ
RAM: 2x 16MB FPM 60ns
VGA: ARK2000PV 2MB PCI, Voodoo2 12MB 3Dfx (manufacturer to be determined)
HDD: 72GB SCSI 15k RPM @ AHA 2940 UW + CD-ROM ACER 52x + FDD 3.5''.
Audio: SoundForte 16S ISA
Misc: & Creative Video Blaster RT300 ISA + cardslot fan assembly & 5.25'' slot fan assembly.
NIC: Compex RL2000A PNP ISA
PSU: 230W AT low price brand
Providing you a little peek to the gallery of this system (From top to bottom of the card insertion):
The Voodoo 2 Accelerator
The ARK VGA
The SCSI Controller
The NIC
The A/V Controller
The Sound Card
The "Cheetah"
And the overall innards of it all
Empty
Fully Loaded
All powered by
I'm basically going back to me previous thread and problem unresolved (rather workarounded by Linux OSes) here: Old 486 Build - Final
This time I was inspired by this thread Storage options on 486, feedback, mainly the part with the SCSI theory unburdening the CPU from the storage work needed to be performed by introducing a SCSI HDD subsystem. So I did.
I bought the AHA 2940 UW PCI card for 7e from a local guy here, perfectly working at the very first time, nice firmware, easy settings interface. Found my pet at the first, formatted after an hour, no problems. There was no need to add any DOS drivers for the controller since its bios handled this, also informing me about this by a short message. Loading a driver to the config.sys makes the driver use the Int 18h option, just FYI. I used the Partition Magic 8.0 Rescue Diskettes to create desired partition architecture, started the Windows 95C OSR2.5 installation, completed with no problems.
Then at the very first boot, I've encountered a HDD read / write error at drive C: (can't really remember the exact message). Rebooted, same happened. I suspected the original Microsoft driver to be acting weird, since in my overall experience with HW and MS drivers has been such, thus I copied the proprietary drivers right from Adaptec to the C:\Windows\System\Iosubsys folder - that did the job, but before this, I had booted with my IDE HDD with the onboard controller just to check whether the driver from MS is working - of course not, it had had an IRQ conflict with the PCI IRQ Steering Driver. Replacing the driver from Adaptec eradicated this issue.
Finally got to the desktop, began to install drivers, tuning the system and so, and - finally to get to my freaking problem - at every 7th to 10th reboot after installing anything that requires restarting the system I get the Windows Protection Error error.
I have no HW conflicts, nor such anything visible that could resemble I/O address conflicts or any IRQ problems, and googling out the net got me these possible inconveniences that may arise :
If a real-mode driver and a protected-mode driver are in conflict.
If the registry is damaged.
If either the Win.com file or the Command.com file are infected with a virus, or if either of the files are damaged.
If a protected-mode driver is loaded from the System.ini file and the driver is already initialized.
If there is a physical input/output (I/O) address conflict or a random access memory (RAM) address conflict.
If there are incorrect complementary metal oxide semiconductor (CMOS) settings for a built-in peripheral device (such as cache settings, CPU timing, hard disks, and so on).
If the Plug and Play feature of the computer's basic input/output system (BIOS) is not working correctly.
If the computer contains a malfunctioning cache or malfunctioning memory.
If the computer's motherboard is not working properly.
If you installed Microsoft Office 97 and you are using the Novell Client 32 software.
I'm trying to concentrate on the highlighted ones, because I often get Memory Test Fail during POST error using soft resets, the cold one always erases this problem. Really not sure what might be the problem, nothing visible, which leaves me with nothing than trying different drivers in the OS for now. Switching the cards in the system doesn't help since the SCSI controller firmware resource settings cannot be altered, not in the OS also.
I will test some games in the first few moments of the problem-less state and verify whether it is acting weird whatsoever, that will put som stress on the resource management, hopefully will get me some more insight.
Any leads guys? Don't wanna swap the controller with something else, it beautifully fits in the case and is has a lot of space for air circulation and GTA 1 has definitely become playable using this SCSI solution - wanna keep it that way.
MOBO: PVI-486SP3 Rev 1.2
CPU: POD-83
RAM: 2x16MB
VIDEO: Matrox Millenium 2MB/Voodoo2 12MB/Video Blaster VT300
AUDIO: SB Vibra16 FM
SCSI: 72GB 15k RPM HDD/YAMAHA CD-RW 16x/ZIP drive + FDD drive
NIC: 3Com Etherlink III
PSU: 230W Generic
OS: Win95 OSR2.5
