First post, by Stojke
I am trying to get my (damn) Vectra 5 XU to install DOS and CD ROM and etc.
I managed to install DOS using an other PC onto an Maxtor 850MB IDE drive.
I installed MS DOS 7.10 but i can not find a way to get my SCSI CD ROM to work. This is the controller chip:
https://dl.dropbox.com/u/54462712/Retro/IMG_4854.JPG
Drivers are no where to be found. But i think I'm not searching properly.
Windows NT 4 and 3.51 detect it perfectly.
Additionally, some one would save me a whole lot of complication if they explained how to have both DOS and NT on one Hard Drive.
Reply 1 of 8, by tayyare
As far as I now you donT need to have a brand specific SCSI CDROM driver. You should have a generic ASPI CD driver, BUT you should also need to have ASPI manager for your SCSI controller's speciifc brand.
This might help:
http://www.hiren.info/downloads/dos-files
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 2 of 8, by Stojke
Was on this site before posting the topic and didnt see this:
AMD PCscsi ASPI Manager (Qlogic Fast!SCSI Basic, Tekram DC-390, Dawi DC2964F)
God im blind! Thank you 😀
Reply 3 of 8, by tayyare
No problem at all, glad it helped.. 🤣
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 4 of 8, by Stojke
7 hours have passed and i still haven't managed to gain access to SCSI CD ROM -___-
The driver loads perfectly, detects HDD and CD ROM. FDISK can see the HDD and read it.
BUT, MSDEX can not load the fuggly CD DRIVE 🙁
Can any one help?
Content of Config.sys:
DEVICE=HIMEM.SYS /testmem:off
FILES=30
BUFFERS=20
DEVICE=cd1.SYS /D:banana
rem DEVICE=cd1.SYS /D:banana /P:1f0,14
rem DEVICE=cd1.SYS /D:banana /P:170,15
rem DEVICE=cd1.SYS /D:banana /P:170,10
rem DEVICE=cd1.SYS /D:banana /P:1e8,12
rem DEVICE=cd1.SYS /D:banana /P:1e8,11
rem DEVICE=cd1.SYS /D:banana /P:168,10
rem DEVICE=cd1.SYS /D:banana /P:168,9
DEVICE=AMSIDA.SYS /V /L
DEVICE=A:\AMSIDA.SYS /D:SCSICD
LASTDRIVE=Z
Content of Autoexec.bat:
@echo off
MSCDEX.EXE /D:banana /L:R
MSCDEX.EXE /D:SCSICD /L:T
Reply 5 of 8, by Old Thrashbarg
Do you have an IDE CDROM drive installed as well? If not, remove the "DEVICE=cd1.SYS /D:banana" line.
Also, you shouldn't have two lines for AMSIDA.SYS, condense that down to:
DEVICE=[path]\AMSIDA.SYS /V /L /D:SCSICD
With [path] being wherever the driver is located... preferably on the hard drive rather than a floppy. And actually you can leave off the /L switch, since you're normally not going to have anything that uses more than one LUN.
For your autoexec.bat, if you only have the SCSI CD drive, delete the line "MSCDEX.EXE /D:banana /L:R".
If you do for whatever reason have an IDE CDROM installed, you still shouldn't be calling MSCDEX twice... do this:
MSCDEX.EXE  /D:banana /L:R /D:SCSICD /L:T
If the driver is loading properly, you should see a line of text on startup, something to the effect of "AMD PCSCSI ASPI Manager for DOS" or whatever, and probably some information about attached devices (which is what the /V switch does on AMSIDA.SYS).
Reply 6 of 8, by Stojke
Its my universal boot floppy i use on every system thats why i left it.
Ok now i have corrected everything as you wrote i should and it sill loads the driver but does not detect my SCSI CD ROM. And i know its functional because NT 4 and 3.5 can use it perfectly and it reads discs.
This is whats on the screen at the moment:
Starting MS-DOS...
AMD PCscsi ASPI Manager for DOS version 3.14
(C)Copyright 1993-1996 by Advanced Micro Devices, Inc.
SCSI ID: 3 LUN: 0 TEAC CD-ROM CD-516S
SCSI ID: 5 LUN: 0 QUANTUM FIREBALL_TM3200S
ASPI Manager Installed
Device driver not found: 'SCSICD'
No valid CDROM device drivers selected
A:\>_
Autoexec:
@echo off
MSCDEX.EXE /D:SCSICD /L:R
config:
FILES=30
BUFFERS=20
DEVICE=A:\AMSIDA.SYS /V /D:SCSICD
LASTDRIVE=Z
Reply 7 of 8, by Old Thrashbarg
Ah, OK, I get it now. It seems you're missing a piece: AMSICD.SYS. Try this package, I believe it's the complete set of files (though I'm not positive since I can't extract it on my Vista64 machine).
With the additional file, your config.sys should have something more like:
DEVICE=[path]\AMSICD.SYS /D:SCSICD
And your autoexec.bat would remain unchanged.
Reply 8 of 8, by Stojke
Oh i see now, since that file is too big for the boot floppy im gonna place it on the HDD.
To ensure proper booting i should first load the SCSI controller for both HDD and CD than the CD ROM controller, right?
