First post, by exofreeze
- Member
Messing around with the old shareware game, Stick Fighter 1 and the flickering is so bad that it is basically unplayable on 0.74. I tried really bringing the cycles down, but even at something as low as 250 it still flickers horribly. I also tried launching them higher, but that just made it worse.
Also tried machine set to ega and vga.
Normally I'd just skip something like this and go on to another game, but I decided to post because I have dealt with flickering in other titles as well, and was hoping that whatever fix might be applicable here would also work there.
edit: It seems Stick Fighter 2 suffers from the same problem, with the added issue that it freezes up if the soundblaster is enabled in the conf file.
