IDE Cables
First post, by tayyare
I just realized something stupid. IDE cables comes in different fashions. I'm not talking about 40 wire/80 wire difference. Later IDE cables have one pin missing/disabled, so cannot be connected to older connectors with no missing pins.
How can we solve this problem, any suggestions? Is there any way to find specifically old IDE cables?
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 1 of 2, by HunterZ
Break the pin off of the older connector if it isn't being used?
Use a hot needle or a Dremel to make a hole in the spot on the cable that is missing one?
Collect enough cables so that you have enough of whatever time you might need?
Reply 2 of 2, by tayyare
Collect enough cables, yeah , right...🤣 ıt's so easy locally, you know. By the way, I have tons already, problem is everyone one them has a blocked pin, except three, and I need four.
Dremel option sounds much better, thanks a lot!... 😀
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
