Motorhead
Reply 20 of 64, by dosmax
For everyone who is experiencing the crash described in the first post of this thread:
I made a .sdb patch that applies the required Application Compatibilitiy Toolkit adjustments without the need for the ACT to be installed.
- DWM is disabled
- DirectDraw Emulation is forced
Simply unpack the attached ZIP and run motorhead_compatibility.bat
You might still want to set the game to Win98 compatibility mode, but for me it runs fine without that (on Win7/32).
Reply 21 of 64, by filipetolhuizen
DirectDraw emulation? Sadly the game loses D3D acceleration.
Reply 22 of 64, by dosmax
I didn't even know the game has a D3D mode, are you sure? But anyway, you can always use Glide through a wrapper.
I for one use nGlide, which works great. But other wrappers might work too.
Reply 23 of 64, by filipetolhuizen
Does the wrapper work with this fix? Even the wrapper requires Hardware functions which are not available in Emulation mode, unless it runs on a separate process. I play Motorhead in D3D mode here. OS is WinXP 32 bits. Works out of the box.
Reply 24 of 64, by HunterZ
WinXP 32-bit is a very different animal from Win7 x64, especially as pertains to running old Windows games.
Reply 25 of 64, by dosmax
Yes, absolutely fine.
But why bother, if it works for you without any fix? Most likely the fix doesn't do any good on WinXP at all. I'm surprised you were able to install it. It's meant for the crash bug mentioned in the first post here.
If you can start the game, see the menu and start a race, there is no need to apply this fix. Not on XP and not on any other OS.
Reply 26 of 64, by filipetolhuizen
It works under XP with no additional fixes. It's just fully patched. Forcing Direct Draw emulation will disable D3D in any game for me. Good to know that it has no effect with the wrapper.
Reply 27 of 64, by tgomola
Sorry for bumping this thread, but I've just found a solution of the problem. I think it may be helpful to someone else.
I followed the instructions on the nGlide page, and guess what - Motorhead works perfectly now, no errors showing. Here are the Compatibility Administrator fixes that need to be applied:
CorrectFilePaths
EmulateDirectDrawSync
EmulateEnvironmentBlock
EmulateFindHandles
EmulateGetDiskFreeSpace
EmulateHeap
GlobalMemoryStatusLie
SingleProcAffinity
Thanks for all your help, guys 😀
Reply 28 of 64, by filipetolhuizen
Thanks. That will be very helpful when I install Win7 here.
Reply 29 of 64, by Futterama
I just regeistered to write in this old thread.
I have Windows 7 64bit and the original Motorhead CD. I cannot get the installer working (/motor/disk1/setup.exe) no matter what compatibility mode I run it in. The installation process just won't begin.
What can I do?
Reply 30 of 64, by Futterama
Oh, sorry, the installer was halted by some program.
Now, I restarted my PC, turned antivirus off and set compatibility mode for setup.exe to Windows 95 and ran the setup.exe. I then get this error:
"Motorhead is designed for Windows 95 and cannot be run on Windows NT."
Reply 31 of 64, by filipetolhuizen
Maybe Setup.exe points to another .exe on the CD, so you need to set it for Win95 compat. as well. If not, you can try changing the OS flag from WinNT to whatever it was on Windows 95/98/Me in the advanced system settings. I never tested this, but this must be where the programs checks for the windows version.
Reply 32 of 64, by vasya segment
Hi people,
I can see this is an old topic, but it suites my question the best, so maybe it's a good idea to post here.
I'm trying to run Motorhead under Windows 7 64-bit through nGlide 1.01.
The game starts fine, race runs perfect, BUT! ... at the finish it freezes and gets stuck. Then, Windows 7 closes it, obviously, due to lack of response from the game.
I know it's a very old game, and I had a lot of trouble trying to install/run it. (installed under Windows 98 SE inside VmwarePlayer, copied files to Windows 7, the physical machine, applied third-party REG-file to be able to run it).
What can I do in current situation?
P.S. I didn't use Microsoft Application Compatibility Toolkit, and didn't use Compatibility mode, inside the properties of executable. Is there a connection to the bug I've experienced?
Reply 33 of 64, by filipetolhuizen
Maybe a nGlide problem. You could try in D3D mode. It runs great for me. I use Win7 32 bits.
Reply 34 of 64, by leileilol
You could also try it in software mode too. DiCE did an awesome job with the software renderer, so the only real compromise is texture filtering and smooth colored lighting.
FUCK "AI"
Reply 35 of 64, by vasya segment
I've tried all modes: software/d3d/3dfx. I've also tried Microsoft Application Compatibility Toolkit. No use. Each time I'm getting near finish line of the last lap, the game freezes and Windows closes it.
Reply 36 of 64, by filipetolhuizen
I just completed a race in single race mode. I'm using D3D mode. Are you using the latest patch?
Reply 37 of 64, by Gamecollector
IIRC Motorhead need lowering of audio acceleration level... Maybe this is the cause for crash.
Reply 38 of 64, by vasya segment
I finally managed to run the game without errors. I had to apply so called HUD patch. Problem solved))))
Reply 39 of 64, by CARLITOS
Hi, I registered expressly to post here because since last day I've been searching the reason and the solution to resolve the problem of Motorhead not running on Win7 64b.
With the ZIP file of the user dosmax: posting.php...p;p=234882
I can run the game, trough the Microsoft Compatibility Toolkit, but the game opens without the intro video, and the music not sounds 😢
What can I do?
Thanks, I hope anyone reads this!!
