Faulty floppy
First post, by sunaiac
Hi guys,
what is the best way to find what is faulty in a floppy chain ?
I got a shuttle HOT433 on which I fail to launch dos setup.
It begins, and ends in an error reading the file, with the Abandon/Retry/Fail usual stuff.
I (We actually) tried 2 floppy drives, several disks, 2 floppy cables, checked and rechecked connectors.
The only common part is the motherboard in all our tests.
Is there a way to be definitely sure the MB is faulty ?
Reply 1 of 4, by Joey_sw
what type of error depend on what the DOS said before the "Abort/Retry/Fail"
-fffuuu
Reply 2 of 4, by sunaiac
Err, I don't remember exactly.
Not an I/O error, more like a read error, but I don't remember the exact sentence.
R9 3900X/X470 Taichi/32GB 3600CL15/5700XT AE/Marantz PM7005
i7 980X/R9 290X/X-Fi titanium | FX-57/X1950XTX/Audigy 2ZS
Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
Ppro 200 1M/Voodoo 3 2000/AWE 32 | iDX4 100/S3 864 VLB/SB16
Reply 3 of 4, by JaNoZ
Have you tried to disable onboard and use an isa multi io card instead with fdd controller?
Or maybe an irq conflict with some device.
I assume the light of the fdd is out when posting the mobo, maybe the cable is reversed?
Reply 4 of 4, by sunaiac
Well the light goes on at post, then the boot disk is recognised. I can actually boot on very simple boot disks.
But none of my DOS installation disks can go to the end...
