First post, by Neville
...but now I can't copy any files into it.
I followed the guidelines from this thread up until step five, which states:
5. Change the above lines in your dosbox.conf to the following : […]
imgmount c [insert path and file name of hard disk image] -t hdd -fs fat -size 512,63,16,1024
mount d [insert path of directory to which you can to copy files from/to the hard drive image]
boot [insert path and file name of hard disk image] -l c
Your hard drive image will now boot to DOS and you can do useful things with it. You will need to mount a directory or images to copy files to/from the disk image.
But although DOSBox mounts my folder C:\UTIL as drive D:, MS-DOS keeps stating that it can't access it. The UTIL folder contains the SB16 drivers and the Windows 3.X installation files, so it's not like I'm going to accomplish much without it.
I also tried to open the hard disk image file with Disk Explorer and copying those files myself, but I keep getting an error when I open it:
[invalid sector size]
Invalid boot record.
Parameters may not be correct.
My disc image is named c.img and has a 100 MB capacity. Any ideas?
Reply 1 of 11, by HunterZ
I gave up with trying to use HDD images in DOSBox (to boot real DOS and such), because you lose access to pre-existing mounts and the DOSBox mount command (meaning that you cannot mount CD images or host folders or anything useful like that).
What are you trying to achieve by booting real DOS in DOSBox?
Reply 2 of 11, by Neville
32 bit disk acces under Windows 3.X. There are a bunch of games that use it.
Reply 3 of 11, by ripsaw8080
Rank DOSBox Author
DOSBox Author
What geometry parameters are you using (the -size parameters)?
The example you mentioned is for an ~500MB image; for 100MB it would be more like "-size 512,63,4,812".
Reply 4 of 11, by Jorpho
Theortical alternatives to DiskExplorer include vmware-mount, filedisk (see also http://www.msfn.org/board/topic/26216-for-vmware-users/ ), Winimage, and OSFMount.
However, if the geometry is borked somehow, they probably won't be more effective.
Reply 5 of 11, by Neville
True, I've corrected it in the AUTOEXEC section of DOSBox.conf. However, this couldn't possibly cause the problem with Disk Explorer, could it?
Thank you. WinImage worked at the first try. Now I've been able to set up the SB16 drivers and install Windows 3.11. I'll still need generic CD-ROM drivers for DOS, but I think I have ones that will do the trick.
Reply 6 of 11, by ripsaw8080
Rank DOSBox Author
DOSBox Author
No, but if you mount the image with correct parameters you can use DOSBox to copy files to/from it as in the guide you referenced.
Official DOSBox does not support cdrom drives after booting, but you can use an ISO written to the HD image with SHSUCDHD to create a virtual cdrom. Ykhwong's build has IDE emulation, so you can try to use a cdrom driver (such as Oak cdrom driver) and MSCDEX there, but dunno how that will turn out.
Reply 7 of 11, by Neville
So I can't, say, imgmount a ISO+BIN as D:, then boot DOS and expect it to be accessible inside DOSBox, even with the proper DOS drivers installed? That's a bummer.
I planned to boot the hard drive image, start Windows, and then follow the install program from the CD-ROM drive.
Reply 8 of 11, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Not in official DOSBox, but you can try with the IDE emulation in Ykhwong's build.
The SHSUCDHD virtual cdrom can be a viable option, but the limitations are that your HD image must be large enough to contain the cdrom image; and only plain ISOs are supported, so no audio tracks.
Reply 9 of 11, by Neville
It's been a few days, so I guess it's time I explain how did it went.
So yes, in the end I had to use Yhkwong's port of DOSBox, because I needed DOSBox to have access to both my 100 Mb. harddisk image with DOS and Windows 3.X and a CD-ROM image.
It all went pretty much like when I installed DOS and Windows on a clean drive back in the days. This included doing some manual editing of both AUTOEXEC.BAT and CONFIG.SYS, because not all drivers you think will work do work.
Specifically, I couldn't get CTMOUSE (a mouse driver derived from the FreeDOS project, I think) to work, and I ended up using another DOS driver (Microsoft's v8.00, I think) which didn't have any documentation.
Also, the mounting instructions, for somebody used to frontends, are a bit of a pain in the ass. I ended up creating a BAT file for every game, which pretty much was like this:
imgmount d e:\<CD Image> -t iso
imgmount c e:\<Harddrive Image> -t hdd -fs fat -size 512,63,4,812
boot e:\<Harddrive Image> -l c
And then mounted the folder with all those files (CD image, Harddrive image and BAT file) as E: in the frontend.
And well, do the games that need either SHARE.EXE and / or 32-bit disk access work using disk images? Yes, they do, although not always. My biggest success so far has been with "Lunicus", a port of a Macintosh game:
Other games, such as "Critical Path" and "Ice & Fire" still show issues, from minor error messages regarding sound output to refusing to recognise the CD-ROM as a proper copy.
But that's another story...
Reply 10 of 11, by Jorpho
It might be included in FreeDOS, but it's not really part of the FreeDOS project, per se. Anyway, older versions do not support the PS/2 mouse emulated by DOSBox; the latest version at http://cutemouse.sourceforge.net/ is the way to go. According to DOSBox-X branch , you also might get away with using "serial1=serialmouse" in the DOSBox.conf.
DOSBox-X branch also suggests that IDE emulation has to be explicitly enabled in the DOSBox.conf, though I haven't messed with it myself.
Reply 11 of 11, by Neville
Thanks for the tip, I already solved the problem by using a different driver, but it may be useful for future reference.
Oh, and I forgot to mention another "issue": there's no way to tell DOSBox to finish after the program exits, you have to close it manually. Of course, there's no "switch off" command under MS-DOS 6.22, that would be too much to ask.
