How to make a Voodoo2 SLI cable
First post, by rug
You can make one from a floppy drive cable. Here's a wiring diagram that shows you which wires need to be reversed.
http://www.soldcentralfl.com/quakecoop/files/v2_pinouts.gif
I found this somewhere on the web. I think this should be added to the vogonswiki voodoo2 part, but I don't quite know how to do that.
Cheers,
Rita Graça.
My DOS machine: MS-DOS 6.22, Pentium MMX 200MHz, 64MB RAM, AWE64 Gold, 4GB HD, Philips 19" CRT, 3"1/2 Floppy, CDROM, Parallel ZIP, ThrustMaster FLCS+TQL+Elite.
Reply 1 of 33, by JaNoZ
Thanks i needed it, i already made one, but still need to test it for proper function.
Also is it or is it not possible to run 4 V2's in SLI? as i saw some pages about before, i would like to try and make a SLI cable for that one 😀 anyone has a pinout for that?
Reply 2 of 33, by northernosprey02
I think floppy cable can be an alternative of V2 SLI cable. So, try using floppy cable as V2 SLI cable. Hope it's working
Reply 3 of 33, by SPBHM
Reply 4 of 33, by Scylla
SPBHM wrote:
http://i46.tinypic.com/2njk4rm.jpg […]
Excellent! I'll keep this for future reference.
Reply 5 of 33, by rug
Yes, but this should be incorporated to the vogonswiki at:
www.vogonswiki.com
Or is this not being maintained anymore? I'd do it myself, but I'm completely clueless with wiki stuff.
Cheers,
Rita Graça.
Reply 7 of 33, by rug
RacoonRider wrote:
Brilliant!
Cheers,
Rita Graça.
Reply 8 of 33, by rug
RacoonRider wrote:
Dear RacoonRider, can you add my first .gif too, please? Because that one has the pin-out (and you need that to build the cable), although less information about the cable itself.
Cheers,
Rita Graça.
Reply 9 of 33, by d1stortion
In case anyone is wondering, I put the content in a new article.
Reply 10 of 33, by RacoonRider
Dear rug, I thought that was the same picture when I edited the article. Since the image is sufficient to make a cable, I added your blueprint as a link. btw, distortion just made this into a separate page, I should have thought of that 😀
Reply 11 of 33, by d1stortion
Yeah, I thought your approach was too cluttering on the article. Most people probably think there is too much banter in this article anyway 😉
Reply 12 of 33, by RacoonRider
d1stortion, bingo 😁
Reply 13 of 33, by d1stortion
I'm fine with it the way it is now... 😀
Reply 14 of 33, by Jorpho
Argh, I keep forgetting where to find that. It's not a simple matter of putting together a cable; the doohickey in question was a fairly bulky circuit board.
Reply 15 of 33, by Stojke
Who made the original image?
I was bored today so i remade the one in this thread in illustrator.
Beta, needs improvement and credits:
Reply 16 of 33, by RacoonRider
Stojke, awesome job! In case you don't want the honour of uploading this image on wiki, I'll be happy to do it 😀
Reply 18 of 33, by Logistics
Are the analog RGB signals sent from one card to the next over that cable? If so it may be advisable to use an 80-pin ultra ata cable as it is 75-Ohm just like video cable.
Reply 19 of 33, by Stojke
I dont mind, upload it 😀
I just need to alter the colors a bit. If any one has suggestions and what more text to add, do tell. Also, thanks 🤣
